Suspension Checking for mushrooming?
Old Nov 28, 2010 | 11:29 AM
TYHOGG's Avatar
TYHOGG
Is there any visual indications, or steering indications that would lead me to mushroomed shock towers? I want to make sure everything is solid before i start installing suspension upgrades.
Old Nov 28, 2010 | 11:37 AM
Eric_Rowland's Avatar
Eric_Rowland
It's tough to tell given the normal shape of the towers. One of mine had clear indications (the edge of the hole was not flat.) The other didn't look bad, but needed a few whacks before the STD would go on flat. Depending on your planned upgrades, I'd recommend getting STDs or similar.
Old Nov 28, 2010 | 03:56 PM
TYHOGG's Avatar
TYHOGG
Thanks the std's are on the list. I was looking at the m7 brace with them built in. kill 2 birds with one stone.
Old Nov 29, 2010 | 09:38 AM
unxpectederror's Avatar
unxpectederror
yeah i wanted a M7 brace as well but it seems they are out of stock atm.. anyone know if they will ever be back in stock..?
Old Nov 29, 2010 | 09:49 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have them in stock.
http://www.waymotorworks.com/m7-strut-tower-brace.html
Old Nov 29, 2010 | 10:27 AM
unxpectederror
Originally Posted by WayMotorWorks
Nice ty.. but i just realized though from looking at some more pictures of it that i dont think it will clear my Alta CAI :(
Old Nov 29, 2010 | 12:56 PM
apexer's Avatar
apexer
I have the Alta CAI and the M7 Strut Tower/brace. Clearance not a problem, just had to notch out the rubber seal between the CAI box and hood.
Old Nov 29, 2010 | 07:23 PM
unxpectederror
yay! thanks for the input thats good to know
Old Nov 30, 2010 | 06:19 PM
nopistons's Avatar
nopistons
Will it clear everything on the R50 Cooper? I think the battery is located up in that area, so i dont know if the bar will hit it.
Old Nov 30, 2010 | 07:21 PM
WayMotorWorks
Vendor
No don't put the brace on a Cooper you can dent the hood.
Just get a set of strut reinforcement plates and you'll be fine.
http://www.waymotorworks.com/search....=search&page=1
Old Dec 21, 2010 | 04:22 PM
Destro's Avatar
Destro
^ Damn wat a hustler!
Old Dec 22, 2010 | 06:22 AM
apexer's Avatar
apexer
Here is another tip. The cross bar may touch the bonnet insulation which may raise the rear of the bonnet. I put chalk on the cross brace so that it would show where the brace touched the insulation. I then used a utility knife to score the area that needed to be removed. By hand I pulled out the insulation (not all of it, just enough so the bar wouldn't push up the rear on the bonnet). When everything cleared OK, I sprayed the area where the insulation was removed with black enamel paint. Now with the bonnet up, you'ed never notice the area where I removed the insulation.
Old Feb 19, 2011 | 11:35 AM
stevendoll's Avatar
stevendoll
Check ride height, mushrooming will throw off. If changing suspension components, get new camber plates OEM or otherwise.
Old May 13, 2011 | 06:42 AM
chargedS's Avatar
chargedS
can the rear mushroom? my rear passenger is about 1" lower and misaligned...
Old May 13, 2011 | 12:11 PM
yetti96's Avatar
yetti96
I just had both rear struts replaced and the mounts becasue the shocks would collapse but not expand and the car road low in the back. At times it felt like no suspension was under the rear of the car, it just bounced around over bumps.
Old May 13, 2011 | 12:32 PM
chargedS's Avatar
chargedS
if your shocks collapse but not expand, thats solely because your shocks are "shot"...
Casrio
Apr 20, 2021 01:52 AM
CardinalsRule
Jun 11, 2016 04:34 PM
mimaal
Sep 4, 2015 09:09 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
