Suspension SOS: Stripped Lower Control Arm Bushing Mount Repair
Well, I found out too late that the bolt mounting the LCA bushing casting to the frame does NOT torque to 72 ft-lbs. Supposed to be 44 ft-lbs plus 90 degrees.The result of over torquing the bolt is that the nut inside the frame strips - which is strange if the bolt is supposed to be a torque-to-position fastener. It seems that the "stretch" is in the nut and not in the bolt. Which leads to the question of how to repair the damaged nut. Normally I would insert a heli-coil, but if the nut is the TTP fastener, is the heli-coil appropriate? Or, better put, does anybody out there know how to repair the stripped nut, PLEASE.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
