Cooper (non S) Modifications specific to the MINI Cooper (R50).
Getrag 6speed from Midland 5speed swap.. Problems
Old Nov 14, 2010 | 12:48 AM
MC2402's Avatar
MC2402
Hi guys,
Im still trying to finish this Getrag swap, but I have some questions.
My car is a 12/2002 Cooper (EURO car) and the box im installin is the 2300150429507 box, which is if I understand it not the preferred one, it does not have the good rations.
So to the questions.
1. Will this box fit? Its already on the engine, starter on, flywheel and clutch, but im getting reservations... does not feel right.
2. if I understand it correclty I should be able to use the shifter box from my Cooper, but when I hook up the shifter cables to the selector the cable to select between from left to right it seems to be to short, there is a lot of tention on the cable... any ideas?
At least I cant select all the gears properly..
All help appreciated.
Old Nov 17, 2010 | 03:22 PM
UKSUV's Avatar
UKSUV
Yes...the gearbox will fit and work perfect. You are having problems because you need MCS shifter cables. You cannot use the Cooper ones. I had the same problem.
Old Nov 17, 2010 | 06:49 PM
lizandrooo's Avatar
lizandrooo
How much did it cost both of you to do the swap ? Best of luck to you MC2402! Where are you located ? i want to find a place to take my mini when i do my swap tht has had experiance doing it. Soon enough ill be doing my swap ;/
Old Nov 17, 2010 | 07:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes UKSUV is right you need the S shifter cables.
I actually have put all the parts from an 05 S we are parting out aside so I will have an affordable conversion kit for someone.
Old Nov 17, 2010 | 08:13 PM
lizandrooo's Avatar
lizandrooo
Whats the milage on that getrag ? is it a 6 speed ? i pretty much have the same R50 as that of the texas motor works write up so if its exactly it, BKE and all then id be very interested!
Old Nov 19, 2010 | 12:14 AM
MC2402's Avatar
MC2402
I calculate that total part cost will be about € 1200 (USD 1600). I live in Luxembourg/Europe.
Then I might be able to offload some of the Midland box parts on ebay.de, the broken gearbox, the halfshafts(driveshafts) and starter motor.
Im doing allt he work myself so I cant really calculate any costs related to that, but I can tell you that 10 hours is optimistic, at least with older Minis. Mine seemed to have had no problems, no work done on it, it was almost fused togeather. All bolts took extreeme work to loosen. For me it will take about 2 months to do, maily because of wrong parts delivered (wrong driveshaft and shifter box) and also because I have limited time to work on my car. In total, I probably will spend about 40 hours finishing it.
Old Nov 23, 2010 | 10:14 AM
UKSUV's Avatar
UKSUV
I miss going to the Utropolis mall.... . Used to go there every Monday for the all-u-can-eat wings and yard beers... Anyways, my cost is as follows....now nothing is spot on.....i have had the swap for awhile
Starter, axles, trans mount - 250
06 trans with 2500 miles - 1050 shipped
MCS cables - 2 @ 100 each - 200 total
Plus, I got a MCS ecu harness, ecu, EWS and radiator for free....
So.....what...the total ran me 1500???
Old Nov 24, 2010 | 07:36 PM
lizandrooo's Avatar
lizandrooo
WOW. seems like you got one hell of a deal!
Old Nov 26, 2010 | 09:09 AM
WayMotorWorks
Vendor
Right now I have 4 or 5 6spd trans ranging from 40k to about 70k miles.
Call the shop next week and we'll see if we can get you a setup.
WAY
Old Nov 29, 2010 | 11:32 AM
lizandrooo's Avatar
lizandrooo
WAY
OoOoOo!!! That sounds delightful but i wont be looking at a getrag switch until a year from now. I love what you guys are doing though. Whats the price on doing the swap ? PM me if you have to.
Old Dec 3, 2010 | 12:26 AM
MC2402's Avatar
MC2402
Swap completed, car drives very well. The Cooper S flywheel is a bit heavy but since this car is not a track car (my 500hp M3 will take care of that) its fine, holds the reves well. The gearing is also a bit tall but the 6speeds make up for it.
I recomend the conversion, just be prepaired for a lot of work, time in the garage and additional money spent.
Old Dec 3, 2010 | 10:31 AM
lizandrooo's Avatar
lizandrooo
Congrats! Please do keep us updated!
Old Dec 3, 2010 | 07:14 PM
WayMotorWorks
Vendor
I don't have a fixed price on a kit. Mainly cause the mileages of the used parts vary and I can't charge the same price for an 80k trans that I charge for a 30k trans. When your ready we'll see what we have available and fix you up.
UncDeo
Nov 4, 2019 04:08 AM
CardinalsRule
Jun 11, 2016 04:34 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
