Snow Tire questions
Old Nov 3, 2010 | 02:48 AM
06Cooper's Avatar
06Cooper
Snow Tire questions
Last year I bought 4 new snow tires for my wife's Saab.A month after this purchase we had major engine problems and traded the car for a 2006 Mini Cooper - wow what a different ride !
I would like to use these 4 like new tires on my 06 Cooper.They are 195/65/15 and my wheels are alloy 15".I see that the standard winter tire seems to be 185/15 but the Mini Cooper S uses snow tires up to 205.I understand the S model has 16" wheels but it appears that the body of these two models are the same, except for the hood scoop.Are the wheel wells the same? Can I use these tires? They will probably be mounted on steel wheels to make the seasonal change easier [if that makes a difference].
Thanks!
Old Nov 3, 2010 | 04:51 AM
colinmini's Avatar
colinmini
Yes, I have seen that people have run that size on a Mini. I just gave my old Passat Blizzaks away and the fellow mounted them on steel Mini wheels.
Old Nov 3, 2010 | 05:41 AM
TimL's Avatar
TimL
I currently run 185/65/15s on steelies for my winter setup (195/55/16s during the other 3 seasons).
I was looking into other possibilities for my winter rubber and found this nifty calculator: http://www.1010tires.com/tiresizecalculator.asp
Long story short, yes your 195/65/15s should work just fine, although your overall wheel diameter will be larger, and as a result your speedometer will read a tad slow and your odometer will also be a little off (by about 2% in each case).
Old Nov 4, 2010 | 02:40 AM
06Cooper's Avatar
06Cooper
Snow tire questions
Thanks for the info.I was hoping these would fit.As far as the speedometer running a bit slower, I can live with that.I'm a bit off myself....
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
