Suspension Sitting in a mini does it add take away camber?
Old Oct 31, 2010 | 08:25 PM
minsane's Avatar
minsane
Hey guys:
I just had an alignment done on my 2004 R53. Unfortunately my rear does not allow for camber adjustment. My right rear is currently at -1.3 and my left rear is at -1.1. Will sitting in a this mini on the drivers side add or take away from that -1.3. Does the same apply for the front? I am currently at -2.0 left and right.
Thank you!
Old Oct 31, 2010 | 08:35 PM
Agarwaen's Avatar
Agarwaen
I think you are missing some - signs or something. as you have it typed your rear wheels look like this
And front like this
Thats no good, Positive camber reduces cornering traction on the outside wheel.
The compression of the suspension adds Negative camber.
Old Oct 31, 2010 | 09:48 PM
veggivet's Avatar
veggivet
When a MINI dealership does an alignment, they are supposed to add weights in the car to simulate you in it. I don't think many other places do this. In either case, you'd have to be pretty seriously overweight to significantly affect your camber, and an amazingly sensitive driver to notice any difference.
If your above numbers are all negatives, those look pretty good to me.
Old Nov 1, 2010 | 03:52 PM
minsane's Avatar
minsane
Correction made. I was alittle sick yesterday.
Old Nov 1, 2010 | 06:14 PM
yetti96's Avatar
yetti96
Yes, MINI and BMW do a simulated full load of people. I recall the amount of weight being about 400+ lb (not a full full load) in the MINI when the do an alignment. My service department advised me that this is the best way to do it and get a consistent and expected alignment.
Old Nov 1, 2010 | 07:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you are suppose to align with weight in the car. But I disagree with this idea. Unless you drive around all the time with the same amout of weight they align the car with, your alignment will be off if you align the car with weight in it. I always recommend aligning the car setup the way you drive most of the time. Same kind of theory we use when setting up the race car. Driver weight, and race amount of fuel.
Getrieben
Sep 12, 2024 07:03 AM
09R56
Nov 16, 2022 10:49 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
