A New Member Hello
A New Member Hello
I jst wanted to say hello to the forum. I just joined after purchasing a used 2006 Mini S with extremely low mileage. I have never joined a Forum so I hope I will participate using the proper forums. I do have 2 questions. What are the important difference between 1st and 2nd generation Minis? and How to I turn off the auto climate control? Thanks
Welcome!
You can get a owner's manual from MINIUSA.com, but in the meantime here's a quick link:
http://www.motoringfile.com/files/2006_MINI.pdf
Welcome Mrsjingles !
The 1st Gen had diff mfg of engines (Brazil), and body styles bit different. Federal mandates requred a "face lift" of sorts for later models from 07 and on. Except for the convertible which did not change until 09.
I sorta like the auto climate on, never have to fuss with it once the temp is set. It also runs the A/C at the same time removing moisture aiding in defogging and also lubes the A/C seals during winter months when it gets little or no use increasing seal longevity.
Here is a PDF Owners Manual - Page 77 here has info on your climate control.
http://pdf.textfiles.com/manuals/CAR...l%20Models.pdf
Welcome aboard, from one R53 owner to another!
This forum has tons of helpful info for all MINI owners. Don't be afraid to read sticky threads, search, and if nothing else ask away!
Happy Motoring!
This forum has tons of helpful info for all MINI owners. Don't be afraid to read sticky threads, search, and if nothing else ask away! Happy Motoring!
