Suspension How do i install front sway on 03 MCS ?
Old Oct 30, 2010 | 04:38 PM
Uc13's Avatar
Uc13
Hey guys,
My question is how can i install the front sway bar without having to completely remove the subframe? If i cant do so, does anyone have a link to a good walkthrough on removing the Sub frame. Im hoping there is a way to somehow just lower the rear of the sub to squeeze out the old sway and install the new one. Oh and if your wondering, i got the hotchkiss setup of ebay. Thanks for the help guys!
Old Oct 30, 2010 | 08:15 PM
Dex05S's Avatar
Dex05S
https://www.northamericanmotoring.com...23#post1420223 This is the link I used when I did my LCA bushings. K-Huevo did a greatjob on the post. I did the sub frame drop by myself and it really is the way to go. While you are at it, you want/need to replace the LCA bushings anyhow depending on your mileage. Good luck! Also, Way Motor Works has the Powerflex bushings already installed in the mounts for a very good price, making the whole job a little easier.
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
minipopkart
Aug 13, 2015 05:22 AM
