Suspension ok to mix aftermarket brake pads?
Old Oct 28, 2010 | 09:54 AM
tonester's Avatar
tonester
I just ordered 4 replacement zimmermann rotors for my MCS. I currently have a set of EBC greenstuff on the front for about 3 months. I am looking to replace the rear OEM pads along with the new rotors. I was planning to not spend too much for the rears because most of the work is done in the fronts anyway. EBC Greenstuff for the rear is around $75. I am looking for a cheaper alternative. Does anyone have any suggestions? Is it ok to run different aftermarket pads on the front and on the rears?
thanks
Old Oct 28, 2010 | 01:35 PM
Crashton's Avatar
Crashton
Might make a difference & might not. I know some auto x's use different compounds to help the car rotate under braking. If it was me I'd spend that small amount & put the same pads on the rear.
Just my .02....
Old Oct 28, 2010 | 03:53 PM
old81's Avatar
old81
M6
I would go with matching pads, but it won't make a difference.
I run the Carbotec bobcats front and XP8 in the rear, since I am lazy.
But I ran a long time with factory MINI pads on the front and the XP8s in the rear without any negative braking action.
If your putting on new rotors, I would match out the pads to manufacturer.
Don
Old Oct 28, 2010 | 04:41 PM
MINI33342's Avatar
MINI33342
Why on earth are you running a higher performance pad on the rears and not the fronts?
Track day/autoX drivers will use a higher performance pad up front as the front brakes are under the most use/abuse.
No problem with running different pads front to rear as long as they are not to far apart in composition.
Old Oct 28, 2010 | 05:16 PM
tonester's Avatar
tonester
MINI33342: i think you read my post wrong. i'm currently running EBC greenstuff on the front. I was thinking of getting either Mintex or Pagid for the rears.
my MINI is just a daily driver, no track day or AutoX
Old Oct 28, 2010 | 05:27 PM
MINI33342's Avatar
MINI33342
Sorry, I was commenting on old81's post.
Old Oct 28, 2010 | 05:29 PM
tonester's Avatar
tonester
so if i had to go with something other than EBC in the rear, which should i go with? (Bendix, Mintex, Jurid, Pagid)?
Old Oct 28, 2010 | 05:41 PM
ZippyNH's Avatar
ZippyNH
I remeber the EBC website had a chart...
It said the greens were ok with the OEM/ebc ultimates...but not reccomended with the yellow's or red's if I remember right. Remember, the greenstuff for the rears are a pretty new development...I think they just became avalable about 2-3 years ago...
So oem rears or an upgraded street pad on the fronts should be fine.
That having been said, maybe moderately upgraded should be stated!
I have been running Zimmerman Rotors on the rear for 2 years... They are wearing great...seem to be a good quality product.
Old Oct 28, 2010 | 06:09 PM
old81's Avatar
old81
M6
I can understand your thought. Since the rear brakes on the MINI R56/R53, etc. do not get used to any great degree, I find leaving the XP8s in place is fine.
Now If I change out rotors (me being lazy), I will probably make the match closer front and rear.
The XP8s are in place for when I do track days and put XP10s or XP12s on the front.
As a data point, even with the all my pad changes, I have not worn out my original MINI R56 rotors.
Going strong at 32K, but I suspect the next track day or two to take care of that.
My thoughts would be EBC front and rear or Bobcats front and rear for street and twisties.
Track I like the way the XP10s/12s modulate, so will probably stay with carbotec.
Don
Old Oct 29, 2010 | 05:17 PM
MINI33342's Avatar
MINI33342
Don
Ahhhh......I thought that would be the case, but the post wasn't real clear about changing the pads for track days.
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
hispdvic
Aug 24, 2015 04:16 PM
