lights, Help Please!
Old Oct 27, 2010 | 10:56 PM
tobee's Avatar
tobee
Ok so i just got a 2002 cooper s and my left head-light stopped working. NOT the fog or the high-beam the Hid dr2 bulbs. To make the story short, I tried replacing it with a new one and it doesn't work! I think it may be something with the lighting fixture. BUT the highs and fogs both work on both sides, and of course the headlight works on the right side.
Any suggestions???? please help me
Old Oct 27, 2010 | 10:58 PM
JustinGTP's Avatar
JustinGTP
when it comes to the xenon, it's going to be a bulb or a ballast. since you replaced the bulb already and it's still not working, it most likely could be the ballast (also referred to as control unit).
Old Oct 27, 2010 | 11:03 PM
tobee's Avatar
tobee
cool
ok if its the ballast, then what is usually wrong with it?
does it have a fuse etc...
Old Oct 28, 2010 | 10:32 PM
JustinGTP's Avatar
JustinGTP
If one headlight is working, it's not the fuse. The ballast is an enclosed unit that would have to be replaced. I don't think the end user can repair them.
Old Oct 28, 2010 | 11:38 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'd also put the old bulb back in. Xenons change in color ever so slight when they age. Replacing only one bulb would make this change very apparent. It would take years to balance out.
Replacing in pairs seems the way to go, as with conventional headlights, which dim as they age.
Old Oct 30, 2010 | 05:00 PM
tobee's Avatar
tobee
ok well...
ok well... thanks guys I appreciate your help
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
