Navigation & Audio changing headunit without/ HK
Old Oct 26, 2010 | 08:23 PM
yubbi's Avatar
yubbi
When I'm changing the head unit, should I disconnect the battery first? or can I just do it w/out disconnecting it?
How about fuse?
Old Oct 27, 2010 | 03:39 PM
aDeLoreanGuy's Avatar
aDeLoreanGuy
As long as you aren't cutting out the original HU plug, you should be fine. Just pre-wire your harness adapter ahead of time. Then you can simply unplug the old HU and plug in the new one without disconnecting the battery. It's when you start cutting up the stock harness or the connected adapter (never recommended) that you need to think about disconnecting the battery.
Old Oct 27, 2010 | 04:10 PM
daflake's Avatar
daflake
I always make a habit of cutting the power when working with electronics. It is better to be safe rather than sorry.
Old Nov 10, 2010 | 04:07 PM
Pnash17's Avatar
Pnash17
How do you disconnect the battery?
Old Nov 10, 2010 | 04:34 PM
daflake's Avatar
daflake
Cooper S? Batter is in the boot under the carpet. Simply remove one of the leads off of the terminal. Don't close the boot lid until you reconnect the battery.
Kimolaoha
Jul 5, 2023 01:04 PM
embiggenedmini
Oct 15, 2015 12:36 PM
shark715
Aug 30, 2015 07:01 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
