hub centric rings question
Old Oct 25, 2010 | 08:01 PM
vettestripes's Avatar
vettestripes
Do hub centric rings the same for all wheels?
For example, I think hub centric rings for Mini Cooper is 67 mm, would that size work for all wheels that need hub centric rings?
Thanks,
-Mike
Old Oct 25, 2010 | 08:18 PM
Mach V Dan's Avatar
Mach V Dan
First of all, the hub size on a MINI is 56.1mm. Secondly, the hubcentric ring needs to match both the car and the wheel. The outer diameter of the ring will be the same as the inner diameter of the hole in the wheel.
So if you have a wheel with a 67mm bore and a car with a 56mm bore, you need a set of 56-67mm hubcentric rings.
--Dan
Mach V
Old Oct 25, 2010 | 08:20 PM
vettestripes
Thanks Dan!
-Mike
barnoun
Sep 17, 2018 05:04 PM
thebordella
Aug 31, 2015 01:37 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
kpl
Aug 11, 2015 04:52 AM
jrezzo
Aug 9, 2015 10:32 PM
