R56 What size wheel spacers?
Old Oct 21, 2010 | 10:29 PM
vjaramillo's Avatar
vjaramillo
I have a set of 17 x 7.5 with 45mm offset and want to push them out flush to the fender. What size wheel spacers can I get that will accomplish this? My 2007 mcs is lowered with eibach springs.
Vince
Old Oct 25, 2010 | 07:55 AM
Hoopty's Avatar
Hoopty
Bump.......
Old Oct 25, 2010 | 08:16 AM
Bigprfed22's Avatar
Bigprfed22
Measure from the tire to the fender...
Old Oct 25, 2010 | 09:54 AM
Rated M's Avatar
Rated M
15 mm all the way around on my jcw 17s. I run h&r and they look great
Old Oct 25, 2010 | 09:55 AM
Rated M's Avatar
Rated M
Double post
Old Oct 25, 2010 | 10:24 AM
slinger688's Avatar
slinger688
I lowered my car with Eibach multi-pro R1 coils and 12 mm rubs with the standard 17x7 crown spokes.
Old Oct 25, 2010 | 11:30 AM
countryboyshane's Avatar
countryboyshane
Just what I was about to say. Be conservative in your measurement or you'll be pulling out the dremmel tool.
Old Oct 25, 2010 | 11:55 AM
iwashmycar's Avatar
iwashmycar
My 17x7.5 et38s sit pretty nice with the fender... so thats 7mm
Id vote 8-10mm (whatever exists). I used to be on H&R springs, and now coils... no rubbing here.
stock 205/45/17
Old Oct 26, 2010 | 01:28 PM
Rated M's Avatar
Rated M
I used this: http://www.1010tires.com/WheelOffsetCalculator.asp
If I use 15mm on my JCW wheels (17x7 et48) to make it flush and your wheels will stick out 9mm father than mine, it looks like flush would be done with a 6mm spacer or whatever is closest.
Mine with 15mm:
Old Dec 17, 2012 | 07:34 AM
MINILANCELOT's Avatar
MINILANCELOT
Secundary problems come out with spacers ?
Does anybody knows secundary problems in r56 with 15mm wheel spacers ?
Old Feb 27, 2015 | 09:33 PM
cguzz's Avatar
cguzz
should I plan on a little shaving with the dremel, maybe a little....???
Old Sep 30, 2016 | 07:15 AM
j.p.francis@wanadoo.fr's Avatar
What is the effect on the geometry ?
Old Oct 1, 2016 | 05:02 PM
bugeye1031's Avatar
bugeye1031
Moderator
You'll need to add some lower camber links to the rear.
http://www.outmotoring.com/mini-coop...trol_arms.html
Old Oct 1, 2016 | 07:25 PM
isamin's Avatar
isamin
I run 7.5 x 17 with 235 (yes) 40/17 andlowered 2". I use 12.5 spacer in front to clear brakes (JCW) and nothing in rear. No problems, handles great, no rubbing and looks truly BADASS.
ISAMIN
Old Oct 2, 2016 | 10:46 AM
isamin
I would love to see what it looks like, I was wondering about doing the same thing.
Any possibility of posting a photo?
TIA
John
Old Oct 2, 2016 | 11:27 AM
bugeye1031's Avatar
bugeye1031
Moderator
For comparison
Old Oct 14, 2016 | 11:55 PM
I just installed 25MM up front on my 2007 R56 with no problem, the fuller look is by no means obvious , it looks just right I will post a photo
Old Oct 16, 2016 | 05:55 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by bugeye1031
For comparison
What's the setup there?
Old Oct 16, 2016 | 07:31 AM
set up: Sock suspension, stock mags, 25MM spacers with long lugs up front . I have not done the math , but I guess spacers all the way around is equal to a lower suspension and slighter squarer wheel base while still maintaining some road clearance?
Old Oct 16, 2016 | 04:56 PM
bugeye1031's Avatar
bugeye1031
Moderator
15mm spacers on all four wheels, stock conical spokes (et 45 I believe), coilovers.
Old Oct 17, 2016 | 03:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Cool, thanks. Looks perfect, in my opinion
Old Oct 17, 2016 | 10:37 AM
isamin's Avatar
isamin
So can anyone tell me how to post script & pictures. I'm an old non-computor man that would love to show you my modded JCW. I know how to reply to posts but don't know the obverse. C'mon, there's got to some geek dork that can help me out. Please?
ISAMIN
Old Oct 19, 2016 | 10:48 AM
bugeye1031's Avatar
bugeye1031
Moderator
Thanks.
The conical spoke et is actually 48....I had it wrong above.
Old Oct 29, 2016 | 06:49 PM
reACTION's Avatar
reACTION
Thanks.
Do you have any rubbing issues?
Old Oct 29, 2016 | 11:52 PM
Mini Mania's Avatar
The wheel application guide will help with offset figures, and here are several options for different thickness spacers. If this doesn't help, please ask!
http://new.minimania.com/Search_Resu...pacers/default
