R56 Mini Cooper Trouble light
Old Oct 21, 2010 | 10:54 AM
Phreek's Avatar
Phreek
I have a 2007 MCS and i'm trying to figure out what this trouble light means.
While driving I get the Brake Light(red) and ACS Light (Yellow Triangle) and on the small display it shows the brakes warning sign. When it comes on it usually only stays on for about 30 seconds, then it goes away. I've checked the wear pad sensors since I just changed the brakes 2000 miles ago. Those look good to go.
I'm lost at what else it could be, unless it is an ABS sensor going bad, but I assumed that I would get an ABS light rather than a brake light if that were the case.
Old Oct 21, 2010 | 10:58 AM
Porthos's Avatar
Porthos
Not sure could be a short or a bad connection. Did you reset the lights after changing the sensors?
Old Oct 21, 2010 | 12:18 PM
Phreek's Avatar
Phreek
Yes, everything was fine until about 3 weeks ago. Now every time I drive it does this. I had no troubles for about 2 months after changing the brakes.
Old Oct 21, 2010 | 12:55 PM
OPC's Avatar
OPC
RATTUS Deserticus
Check your OM for indicator and warning lamp definitions (around page 121). When seen in pairs or triples, they may mean something else. For example, ABS (brakes) + DSC = Vehicle electronics failure and require an immediate dealer (shop) visit.
Old Oct 21, 2010 | 01:04 PM
Akack's Avatar
Akack
Had the same problem 2 months ago....something was wrong with the ABS sensor in my case.
Not sure if you have a MT, but when I had this error the hill assist stopped working as well.
Old Oct 21, 2010 | 01:14 PM
Phreek's Avatar
Phreek
I have the feeling I have the same problem. I have a MT, but never noticed the hill assist anyway. Actually nothing at all seems to take place while this error is on, but it happens pretty often. How did you determine which sensor? Or did you just take it to the dealer?
Old Oct 21, 2010 | 01:21 PM
Phreek's Avatar
Phreek
Oh and BTW the owners manual does not have this particular code in it. I looked for it there already.
Old Oct 21, 2010 | 01:38 PM
Akack's Avatar
Akack
Took it to the dealer and they diagnosed/fixed it. The SA says it was a common problem......
Old Oct 21, 2010 | 01:56 PM
Spridget's Avatar
Spridget
I got a similar display a couple or three times this past summer, and FWIW, they both occurred on very hot days. I haven't seen it before or since.
Ciao,
Spridget
Old Oct 21, 2010 | 02:55 PM
Phreek's Avatar
Phreek
I'm going to try and just clean the sensors, but i dunno exactly which one to start with.... is there one at each wheel?
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
