R55 Cleaner For Arc Fender Flare
Old Oct 10, 2010 | 01:23 PM
ylsirc's Avatar
ylsirc
im looking for the best cleaner for the arc fender flare on my mini.... it seems like white scuff marks are always on it and im not sure if i should use armor all on it....
does anyone have the same problem???
Old Oct 10, 2010 | 06:25 PM
jcauseyfd's Avatar
jcauseyfd
Check the Detailing 101 forum. Black Wow is a popular product with many MINI owners, but you'll find info on some other options as well.
Old Oct 10, 2010 | 06:28 PM
HRM's Avatar
HRM
White scuffs are usually wax that got on them. You can use peanutbutter to get that off.
Old Oct 10, 2010 | 07:43 PM
ylsirc's Avatar
ylsirc
Thanks guys! i think imma try the one grand E.R.V. instead of the peanut oil.... i work near the mountains dont want any nibbles on my car LoLz
Old Oct 11, 2010 | 07:26 PM
slimjimtell's Avatar
slimjimtell
Peanut Butter doesn't work...this only puts a very nice layer of OIL on top of your wax coated plastic. You'll have better luck with rubbing alcohol and a tooth brush, preferably not the one you use every day.
After the alcohol, black wow should make them look great.
Old Oct 11, 2010 | 07:47 PM
TyCrox07's Avatar
TyCrox07
Try a magic eraser. I use the walmart brand. They work like magic... The residue never returns and I haven't noticed any damage in the two years I've been using them.
Old Oct 12, 2010 | 09:04 AM
mbu's Avatar
mbu
The black plastic trim has "small" bumps all over the surface thereby trapping dirt and dust. To clean it, I just use a small scrub brush with fairly stiff plastic bristles and go over the trim with soapy water. One can purchased the brush at Wall-Mart in the kitchen section for around a dollar.
I've found that most products that are recommended to clean the trim have oils in it which only "mask" the dirt and makes it look good until one drives the vehicle down a dusty road - which is like EVERY road - paved or not!
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
ccfirelt
Oct 18, 2015 01:02 PM
pglgp1292
Oct 5, 2015 09:34 PM
drum6g
Sep 29, 2015 01:15 PM
