tail gate noise
Old Oct 3, 2010 | 03:04 PM
craigminuk's Avatar
craigminuk
tail gate noise
as above i'm getting a rattle from the tail gate area i have been told that it could be the catch that needs replacing is this true? i have had the tail gate up and drove the car and the noise goes so so its defiantly coming from the tail gate
Old Oct 4, 2010 | 08:26 AM
buzzsaw's Avatar
buzzsaw
Here's a link addressing the boot latch adjustment that may help. Good luck.
Old Oct 4, 2010 | 09:20 AM
Eric_Rowland's Avatar
Eric_Rowland
Yes. If you're lucky the dealer will replace it. They redesigned the latch receiver.
Old Oct 4, 2010 | 03:05 PM
SteveB625's Avatar
SteveB625
Try a couple of wraps of black tape around the latch wire. It stopped the rattle on mine for over 6 months now.
Old Oct 4, 2010 | 04:41 PM
BillyJ's Avatar
BillyJ
I had this problem myself in my 2010 MCS. There are a number of different threads addressing this issue, but no summary of steps to take...
a. Make sure the flexible bumpers in the hatch are twisted out far enough to give a snug fit when the hatch is closed; be careful though, if the bumpers are out too far, they will bend and become less effective
b. Get the replacement "D-ring" receiver from the manufacturer; it is black
c. You can try a wrap or two of electrical tape around the latch ring, but I did not find this to be helpful
d. Most important; in the R56 snap off the two plastic caps next to the boot latch itself, exposing the two T30 torx screws that can be loosened to adjust the latch itself. I put my latch as far forward as possible, making sure that the d-ring will strike the latch right in the middle
e. Also important: Put a good amount of a heavy lubricant on/in the latching mechanism itself.
My hatch is quiet now, for the time being....
Old Oct 4, 2010 | 05:16 PM
Crashton's Avatar
Crashton
A tech at my dealer told me that was the test for them to see if the latch wire was bad. If the rattle went away the new latch wire went in.
Supertractor3
Apr 7, 2017 11:16 AM
chicohuahua
Oct 1, 2015 10:33 AM
Emnotek
Sep 11, 2015 04:16 PM
charlieglitter
Sep 10, 2015 06:20 PM
CSC_R53
Sep 9, 2015 03:12 AM
