Oil Pressure Light
Old Oct 3, 2010 | 11:23 AM
kennedy71809's Avatar
kennedy71809
Oil Pressure Light
Hey guys quick question for you. I have a 2003 Just A Cooper. For some reason I am gettting a low oil pressure light anytime the RPM's dip under about 1k. This is regardless of gear, idle, temperature, or anything else from what I can tell. The oil level is perfectly fine. I haven't heard anything or felt anything that would say my oil pressure is low. Suggestions? Thanks so much in advance!
Old Oct 3, 2010 | 11:56 AM
Crashton's Avatar
Crashton
Did this happen after an oil change? The reason I ask is there is a part in the oil filter that must be reused. Many times garages not familiar with MINI will forget to reuse the part. The symptom is what you are describing.
Old Oct 3, 2010 | 11:59 AM
kennedy71809
Yes this did start after I changed the oil. I am aware that some MINI's have a plastic piece and a spring in the filter housing. When I changed it there WAS a spring in the housing, no plastic piece.
Old Oct 3, 2010 | 12:02 PM
ZippyNH's Avatar
ZippyNH
+1
YOUR OIL PRESSURE IS LOW!!!
STOP DRIVING BEFORE YOU CAR'S MOTOR IS DAMAGED!!!
You may need to have a part ordered and put it into your oil filter holder...when the oil was changed, it was likely thrown out. There has been many folks with this issue. Do a search.
ZippyNH's Avatar
ZippyNH
DID you use an OEM filter?
Old Oct 3, 2010 | 12:04 PM
kennedy71809
No puralator. Where can I get this part? Also I regret to inform you that I have been driving it for awhile now lol. Hopefully there is no hidden damage!
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
Emnotek
Aug 13, 2015 05:47 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
