R56 Does your Cooper S rattle?
I've just arrived in the US (originally from Ireland) and am on the look out for a nice second-hand Mini Cooper S.
I went to see a '07 recently with about 30k on the clock. The car seemed nice and neat, but what really surprised me was just how much the interior rattled, there were squeaks coming from the front, the rear, up high, down low when ever you hit any bump or imperfection on the road. It made me suspicious that the car may have had a knock or two during it's life.
Is it a common fault?
The car is three years old, I didn't expect it to be rattle free, but this really seemed excessive. I expected better from BMW.
Only my dash rattles, and that rattle depends on speed and temperature. Not bad for an 02 MCS. You're going to have to spend an extra 20 grand if you want a rattle-free car mate. Either that, or turn up the radio.
Depends. Some people have the dealer fix them. Some just ignore it. Its a small car with a very rigid chassis. The runflats don't help and lots of people put on suspension mods that make the car more rigid. I have the JCW suspension on my car and my wife won't even get in it.
Lots of plastic on plastic makes for lots of rattles. It is unfortunate.
Ok
I have been trying to eradicate some rattles which i can now testify have been greatly reduced
Apologies if these have already been posted but here are my solutions some may be well documented already
I wont post pics as they are really self explanatory
Front of car
1) Center grille by hazard flasher
Removed by brute force and sliding a plastic lever under it and prising it off working from the outsides inwards
This held on by approx 5 plastic clips i broke two in the process.
however i snipped them all off with cutters and removed the guiding lugs on the front of the grille so it would just slide straight back in
It is now held in place by strategically placed double sisded tape
No more rattles from this (I think the plastic clips held it on too tightly so that they creaked)
2) whilst the centre grille was off i removed the two screws holding the back of the speedo cowl and inserted two small rubber grommets an re tightened
3) Rev counter - removed the two screws and again inserted rubber grommets on them i also slippred a small 3mm rubber washer in between the underside of the rev counter and the top of the steering column and then re tightened the screws down
4)Secret compartment - affixed two small black rubber washers either side to stop any rubbing
5) Glove compartment - small amount of electrical tape around the catch of the glovebox so it holds more snugly
6) underside of seats are a couple of cables - make sure these are located inside the cable locks that are also under the seat
Rear of car
6) Back seat removed and gorilla taped boot release cable down
7 Aslo where the plastic panels join just below the arm rest and to one side of the rear speaker - they can be prised slifgthly apart aloowing a small rubber washer to be inserted
PS forgot to add whilst on the glovebox i crawled underneath and there are some loose cables behind it which i tie wrapped and wound with insulation tape to stop any rubbing
all for the price of some double sided tape and rubber washers
My car now has a lot less rattles just need the council to sort out the bloody pot holes
Front of car
Rear of car
Ok
Front of car
Rear of car
Front of car
Rear of car
Think I'd like to find one with no/few rattles, as these things only get worse over time. Good to hear there are some people whose Minis don't suffer this afflication!
For those who are rattle free, what model year is your car and how many miles has it done?
They rattle a lot, but it's not like it's excessive to the point where you can't hear people talking next to you. They're subtle and I'm really **** about that sort of thing, but they really don't bother me that much.
I almost feel guilty when I read threads like this, but my '09 JCW with the original runflats and 28K miles on the clock doesn't have a single rattle.
Maybe it was built in the middle of the week; I don't know.
Currently the only thing that rattles in mine is my phone charger. I hate rattles. I have about 24k miles on it.
My 07 that I had a aftermarket stereo installed in and also had coilovers on it had quite a few rattles. I think the stereo install had something to do with it.
Our '05 and '07 both do it, although the '07 is worse.
