Drivetrain Anyone use Harbor Freight's Cen-Tech Scanner?
only $99 per flyer. could use one for Honda Passport winter ride / gfriends Rav4 too.
http://www.harborfreight.com/can-obd...rce=googlebase
Wonder if works well with / clears codes in Mini?
just found this one too, little more complex & $
http://www.amazon.com/Equus-3150-Pro...869442&sr=1-23
These are fine and probably will do a good job.
However, I have a simple code reader that will clear the codes and only paid $50 through Amazon. There really is no need for much because unless you have the MINI specific shop computer you will be just reading general codes.
You can also get a ScanGuage II that will read & clear codes, and give real time info from the ODB port (temp, timing advance, MPG, etc).
I have a ScanGuage in the MINI and use the code reader for the other cars.
R50/53 What is up with my 2005 r53?
rustof
11
Sep 25, 2015 10:35 AM
RocketUSA
Sep 15, 2015 07:45 AM
mimaal
Sep 4, 2015 09:09 AM
