Outer Tie Rod replacement
Old Sep 15, 2010 | 07:49 PM
sprp85's Avatar
sprp85
Hello All.
I am in need of good advises with replacing my outer tie rod.
First of all, this is not my first time pefroming this DIY. Just have a simple issue of getting it loosen.
The lock nut towards the inner tie rod, where you can turn and lock to adjust toe setting, is jammed. I tried and tried but couldn't get it to loosen up.
Anybody have any idea what size open ends I need for the job? Unfortunately, I had some 'not-perfectly-fitting' open ends and couldn't get on it efficiently.
Also, do you loosen the lock nut before loosening up the end bolt (the one you have to get to with allen wrench?)
thank you all!
Old Sep 15, 2010 | 08:09 PM
Calz's Avatar
Calz
There is special tool for the inner jammed Nut. I have a special HD cresent that works perfectly on that so I dont use the special tool.
The outter is a 15 and if you have an impact wrench you dont need the allen. loosen the tie adjuster first
Old Sep 15, 2010 | 09:15 PM
sprp85's Avatar
sprp85
Do you have any idea what size the lock nut is tho?
I remember it was not so difficult to loosening it up before with a basic open end wrench
Old Sep 16, 2010 | 10:19 AM
Calz's Avatar
Calz
I can't remember... The problem is if you buy a combination wrench for it its Too long to swing in the fender to break it... even if the wheel is turned all the way...
If you can find one of the Heavy duty cresent wrenches thats 12 inches long its pretty easy... and cresent wrenches are not expensive at all
Old Sep 16, 2010 | 01:11 PM
Calz's Avatar
Calz
Just checked
24mm
devicemanager
Jun 17, 2016 06:18 PM
maestro39
Oct 27, 2015 02:38 PM
howardeng
Aug 20, 2015 04:38 PM
minipopkart
Aug 13, 2015 05:22 AM
