Rear Trailing Arm Maintenance?
Old Sep 15, 2010 | 09:33 AM
ScottRiqui's Avatar
ScottRiqui
I know to keep a careful eye on the lower control arm bushings in the front of the car, but is there any required/recommended maintenance for the rear trailing arms? I looked on RealOEM.com, and I can't find anything obviously-consumable like a bushing, unless you're just supposed to replace the entire trailing arm as a unit. At $370 per side, I'm hoping that's not the case.
I have about 75k miles right now and will be replacing the rear shocks soon, so I thought it might be a good time to address any other wear items back there.
Old Oct 7, 2010 | 12:17 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I put some power flex inserts in mine....Damn rear brakes grab now like throwing an anchor out the boot. A nice upgrade.
MINI made two different types of bushings for this part. Depends on mfg date of the MINI. PF first sent wrong yellow inserts ( too small ) New ones were much larger in diameter. Again, nice upgrade.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
