New Wheels
Old Sep 7, 2010 | 01:55 PM
DAS MINI's Avatar
DAS MINI
New Wheels
Looking at these...
http://www.enkei.com/ekm3.html#
I've never changed wheels before... what is our bolt pattern an offset?
Old Sep 7, 2010 | 04:55 PM
Herleman's Avatar
Herleman
Unfortunately, I don't see a 4 bolt wheel on the spec chart.
Great looking wheel though.
Old Sep 7, 2010 | 05:33 PM
Dex05S's Avatar
Dex05S
I agree ... good lookiing wheel You may be able to mount them using adapters from 4-bolt to 5-bolt.
Old Sep 7, 2010 | 05:52 PM
MCS Fever's Avatar
MCS Fever
If you go to TireRack.com you can search wheels by application........ LOTS to look at........
Old Sep 7, 2010 | 07:35 PM
DAS MINI's Avatar
DAS MINI
I wouldn't trust an adapter holding up under pressure. so our bolt pattern is 4x100? How about the offset? I'm not even sure what that means
Old Sep 7, 2010 | 09:13 PM
Calz's Avatar
Calz
Racing guys love Enkei... Wheels are light and pretty inexpensive so no worries if you damage them.
Offset is the distance the mounting of the wheel is OFFSET from the center of the wheel. If the offset is zero it mounts right in the middle. If it is +35 it is 35mm towards the out board of the center line center line -35 would be 35mm towards the inner. Some people also go by backspacing with is a different measurement.
Old Sep 8, 2010 | 05:39 AM
MCS Fever's Avatar
MCS Fever
What width and offset are stock wheels?
Old Sep 8, 2010 | 03:10 PM
Calz's Avatar
Calz
16 inch wheels are 6.5 inches wide and the 17s are 7 inches wide. The stock offset is +48 for these.
Old Sep 8, 2010 | 04:10 PM
ScottRiqui's Avatar
ScottRiqui
Yes, the stock bolt pattern is 4 X 100 mm, and the stock centerbore diameter (the hole in the middle) is 56.15 mm.
You can use wheels with a larger centerbore diameter, but it would be a good idea to use adapter rings to make up the difference. Wheels with a smaller centerbore (like early Miata wheels) won't work unless you have a machine shop enlarge the centerbore.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
