Brake Pad Indicator Light
Old Sep 7, 2010 | 11:59 AM
focker's Avatar
focker
The indicator light came on last week and while the front pads look great the rears were ready for a change out. After changing everything on the rear the indicator light is still lit. I even changed out the sensor a second time in case the first one was defective. Is there a reset or any other suggestions to look at?
Old Sep 7, 2010 | 01:01 PM
HRM's Avatar
HRM
The light stays on when the circuit is broken, so if all (including the front) are good, you have to look at the wires. You can short out each one to see if it is one of the sensors. Mine are removed and the wires just twisted together. It makes the light go out, but you have to check them manually.
Old Sep 7, 2010 | 01:20 PM
Capt_bj's Avatar
Capt_bj
yes there is a reset
turn the key to on (aka position 2) but do not start the car, hold in this position for 30 seconds.
This should reset the system
(found this tidbit of info buried in MiniMania's description of replacement sensor)
Old Sep 7, 2010 | 02:57 PM
focker's Avatar
focker
Thanks Capt., that solved the problem
Old Oct 31, 2010 | 04:06 PM
Crashton's Avatar
Crashton
The search does work!!!
Another thanks to you Capt. At 6,000 miles I changed out those coal dust pads. Tied the sensors out of harms way never to be bothered by them again. Until this week when the nanny brake light came on. Come to find out that the plastic of the inner fender had cut into the sensor wire. Replaced the sensor, but the light stayed on, what the heck!!!
Found your post & it's fixed. Thank you!!!
Old Jan 20, 2011 | 04:30 AM
Cadenza's Avatar
Cadenza
I do this to my Mini once a week.... makes it smarter!
Old Feb 16, 2011 | 10:02 AM
nwanderson's Avatar
nwanderson
Brake sensor light still on!
Brake pads were replaced and they told my Dad that the new brake pads wouldn't allow for the sensors to be used, thus the light on. Obviously didn't want to deal with it!! My mechanic looked and found a bad sensor in front and replaced it, and inspected the back one, did the key in 2 position for 30 sec and then start and still the light is on! If there is another break in the wire, would it be confined to the sensor apparatus itself, or could there be a problem past where the sensor wires plug in? I am selling this car - my Dad's 2003 MINI and would like to have it right for the next owner. Thanks!
Old Mar 24, 2011 | 12:35 AM
kimban's Avatar
kimban
Thanks. Did my brakes last weekend and light stayed on (so annoying). I will try this soon.
Old Jul 26, 2011 | 03:13 PM
crazydrumer911's Avatar
crazydrumer911
whenever you change the brack pads you need to change the sensors there like 30 bucks but thats another reason y the light never shut off
Old Apr 12, 2012 | 05:23 PM
mdurando's Avatar
mdurando
not true about needing to change the sensors whenever you change the break pads. If you replace the pads before the sensors are turned on and are careful not to break the sensors when you remove them from the old pads, you can replace them in the new pads and they will work just fine. I've changed my pads twice (on a 05 MCS and an 02BMW 325xi, which has a similar mechanism) without replacing the sensor, and no problems; the lights don't come on. The important thing is to change out the pads before the sensors is engaged; once the sensor is turned on, it needs to be replaced.
Old Sep 26, 2013 | 05:56 PM
Jynyatec's Avatar
Jynyatec
So I just bought an 03 mini. With about 20 mins left in my 2.5 hour drive home the brake light came on along with the ABS and DSC light. Any ideas what it could be. It will go off sometimes and randomly come back. I checked the brakes and the passenger side does not have a sensor in the brake pad like the drivers side.
Old Sep 26, 2013 | 06:43 PM
minibx's Avatar
minibx
There are only two sensors, on on the driver side front brake pad and one on the passenger side rear brake.
About the lights I think that they are indication of a bad speed sensor but please don't quote me on that.
Old Sep 26, 2013 | 07:00 PM
Jynyatec's Avatar
Jynyatec
Thanks for the info. I will check it out.
Old Oct 3, 2013 | 06:42 PM
ageofoctane's Avatar
ageofoctane
This shows how cheap I am, but I don't like replacing things when I can fix them instead.
I used some flush cutters to cut a short piece of copper wire that matched the diameter of the wire that gets worn through on the sensor and soldered it in place. I left the wire exposed because I'm really not worried about it, but one could coat it with a little liquid tape if they were concerned of it corroding or something. I had to scratch away a little plastic around the wire ends on the sensor a little to give the solder more to hold on to, but it seems to be fine, and saved me having to order a replacement this time around.
You don't have to be a soldering wizard, but it helps to have some soldering skills.
I like having the sensor, but I figured if repairing it didn't work, I would just bypass it and keep an eye on my pads.
Old Apr 21, 2015 | 01:17 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Great info.
We have all that info listed on our DIY Tech Article as well.
888.280.7799 | 6am - 5pm PST
Old May 14, 2017 | 06:00 AM
Cenla Mini's Avatar
Cenla Mini
I know you can replace the sensors but does anyone know where you can replace the wire assembly they plug into? My driver side plug housing broke when I replaced it last time and now I need to replace them again...would like to find a replacement if possible. ECS Tuning and Pelican Parts both have the sensors/wires but I didn't see the wiring harness they plug into. (Sensor Mfg Part # is 34356778175)...this is not what I need...I need the wiring harness this plugs into.
Old May 15, 2017 | 09:51 AM
PelicanParts.com
Vendor
Doing a little digging, I do not see that MINI lists the pad sensor harness separately from the main wiring harness. Maybe someone else might have more info for you as well. You might have luck searching your local junk yard for a MINI they're parting out and see if you can snag one off of it. Or the connectors can be listed by size and shape in the electrical section of realOEM here: http://www.realoem.com/bmw/enUS/part...Cooper_S&mg=61. Would splice it in to the wiring harness yourself.
Old May 15, 2017 | 06:02 PM
Cenla Mini's Avatar
Cenla Mini
Thank you! That is one of the things I was considering but finding a Mini in a local junkyard is rare around here. I'll still look...maybe I can find the right connector in realOEM.
Old May 18, 2017 | 08:07 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
Have you PM'd ALLMAGAUTO? I purchased an outdoor air temp sensor and pigtail from them for a great price.
Old May 18, 2017 | 04:09 PM
Cenla Mini's Avatar
Cenla Mini
I may have to give them a shout...someone in one of the part out's said they had what I was looking for but haven't heard back yet.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
penguinhomey
Aug 17, 2015 01:33 PM
