Tire Size Question
Old Sep 1, 2010 | 09:22 AM
MilwaukeeDavid's Avatar
MilwaukeeDavid
Tire Size Question
Can somebody tell me if tire size 225/60 R 16 will work on the rear of a 2004 Mini Cooper S. The front tires will be the 195/55 R 16 continental run-flats. Thank you.
Old Sep 2, 2010 | 07:14 AM
cmt52663's Avatar
cmt52663
that would be a problem....for several reasons:
1. the 225/60 diameter will differ significantly from the 195
2. the 225/60 will raise the rear axle significantly
3. the resulting handling would be unpredictable
honestly not recommended to mix and match brands and dimensions front to rear - you don't want any surprises if you ever have to do a quick lane change, or bend the car into a ramp...
Old Sep 2, 2010 | 11:26 AM
Herleman's Avatar
Herleman
It would also drive the TPMS insane, and the little warning triangle would most likely melt and set the entire dashboard on fire. Well, maybe not, but the TPMS would be very offended.
And they'd probably rub, too.
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
