Navigation & Audio $500.00.....
Old Dec 16, 2003 | 05:08 AM
Nobull60's Avatar
Nobull60
OK here's the deal. I have about $500.00 to spend on a audio upgrade. I don't have H/K. Stock headunit and sound. I want to keep the head unit but I want clarity and some sweeter sounds from the unit. What to get?? The days I was into audio are way behind me and I need some help from the new age experts.
Amp.. which one?
Speakers?? 6x9?? Replace them all??
Woofer?? Is it needed??
Anything I am missing??
Remember I have only $500.00 to spend.
Thanks for the help.
Old Dec 16, 2003 | 05:11 AM
macncheese's Avatar
macncheese
A decent amp (2 channel), some sound deadener and a nice set up components up front. Forget the back speakers, who listens to music backwards?
Cheese
Old Dec 16, 2003 | 07:59 AM
scooterboy's Avatar
scooterboy
If you get an amp, make sure it has speaker level inputs because the stock HU has no line level outputs.
Also get some good speakers front AND back - I personally like the Infinity Kappas. If you seal up the rear enclosures before putting some Kappas back there, you'll get some really good bass response and you won't need a sub unless you really want to shake the car. Click the link in my sig to see how I sealed them up. I put 6.5" rounds in the rear using 6x9 adapters, but 6x9's will sound good too.
If you're as old as I am (41), you may remember when rear speakers were the primary source of sound, and front speakers were supposed to be "felt but not heard". Back then I preferred a somewhat equal balance between front and rear, and feel the same now. Just because the current philosophy is "the front soundstage is all that matters and forget the rear", doesn't mean that's everybody's preference.
Good luck!
_________________
My Mods Page
Old Dec 16, 2003 | 08:18 AM
macncheese's Avatar
macncheese
A lot of high quality amps arent going to have speaker level inputs. I recommend getting a convertor from Dave Navone at: LINK. Good luck!
Cheese
Old Dec 16, 2003 | 08:41 AM
chrisneal's Avatar
chrisneal
Just wanted to pop in and say that I really like these types of threads in the audio forum (I have X amount of money, what should I do?). I know next to nothing about audio stuff, and I'm probably going to be in this exact same situation later this month, depending on the size of my holiday bonus. I always read these threads (as opposed to the more technical stuff in the audio forum), and appreciate everyone's responses. :smile:
Old Dec 18, 2003 | 03:18 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Here is a similar post to yours-
https://www.northamericanmotoring.co...mp;topic=18496
Who is doing the installation? That will add to the price if you add both front and rear speakers.
Infinity Kappas are good and on a strict budget maybe a two channel amp and just the front speakers might work.
If your budget allows Kappas in the front and rear with a four channel amp would work better. PM Pooky13 as she has kappas front and rear.
Dynamat extreme to deaden the noise and reduce vibration is worth it.
On adding front speakers and dynamat
https://www.northamericanmotoring.co...mp;topic=13195
_________________
Aloha
Old Dec 18, 2003 | 08:44 PM
KiLO's Avatar
KiLO
I would get an iPod and the hardware you need to mount it. That's a huge upgrade in my mind
Old Dec 30, 2003 | 11:03 PM
Normalizer's Avatar
Normalizer
Here's mine....
Dynamat Extreme, forget the price but it was worth every penny. Deadens enough sound to in itself be a pseudo amplifier installation due to higher perceived power output and cleaner sound, due to lower road noise.
Polk EX 6.5 components up front, 6x9's in the rear. These have since been replaced with the DB series speakers but appear to have the same specs. $350 for the set, front and rear combined, from Circuit City. VERY nice quality, GREAT sound, and high sensitivity (92/93) so they work great right off the stock headunit, no amp needed. Sounds as nice and clean as the H&K system, though without as much bass, and should last a long long time. If you later upgrade to an amp'd system these speakers can handle something like 300w peak power, 10-100 wats reccomended. So NO problem powerwise....
