Driving light
Old Aug 27, 2010 | 04:15 PM
peterjh85's Avatar
peterjh85
Driving light
Hi all,
Thanks for the informative posts here - I'm new!
I realized that my new-to-me 05 Mini Cooper S "driving" light is not working (I'm not sure if that's what it's called - see pic below for exact light). The bulb works fine when I use the turn signal but when it's on at night or during the day it does not light - only works using the turn signal. I replaced the bulb just in case too. Any ideas?
Thank you!
This one:
Old Aug 27, 2010 | 05:33 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
There are actuall TWO bulbs in there. The larger bulb
is for the directional.
The smaller one a 2825, is a small running light.
It's back is right next to the larger one. Get a hold of it and a 10 degree twist releases it from the socket housing. Replace bulb insert and twist back in opposite direction as before to secure.
Old Aug 27, 2010 | 06:30 PM
peterjh85's Avatar
peterjh85
Great - thanks for the tip!
Could you please elaborate just a bit on how to get the bulb out? I've located the smaller bulb and disconnect the wire socket. I just can't seem to get the black housing out.
Thanks!
Old Aug 27, 2010 | 08:05 PM
peterjh85's Avatar
peterjh85
nevermind - a little wd-40 did the trick!
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
