Suspension ALTA Suspension Components Buyers Guide
Old Aug 26, 2010 | 11:02 AM
ALTAPerformance's Avatar
ALTAPerformance
At ALTA Performance we care enough about YOU, to put extra effort into our products and services, insuring you get the absolute best part at a great price. Drawing feedback from our past clientele, we continually review and revise our products to make them the best choice available on the market today!
We are extremely proud that most ALTA Performance products are Made In The USA. While this does create a challenge for cost vs. goods made by our competitors overseas, we strongly believe it is the correct thing to do! Thus supporting the American economy with the use of raw materials and even more importantly labor! Keeping American’s at work is good for ALL aspects of the industry and economy. Help us in supporting the USA and buy ALTA brand performance parts for your Subaru!
We carry a wide variety of the "bread and butter" parts that make your MINI perform! Want to make an even larger jump in performance? Then check out our specialty parts such as PSRS, Adjustable Rear Control Arms and Package Deals. We also cary the full H&R Suspension line to complete your suspension overhaul. Read on to see what we have for your MINI!
Sway Bars
The first suspension modification we recommend is a stiffer rear sway bar. In short a sway bar upgrade will keep the car flatter during a corner allowing the tires to use all their grip to get you around the corner. Sway bars are also used to "tune" the handling of your MINI, your car is set up from the factory to under steer quite a bit. Fit a stiffer rear sway bar and you will reduce the under steer to a near neutral set up, perfect. ALTA sway bars have multiple end link mounting positions to allow for fine tuning of the bars effectiveness. A stiffer rear sway bar is a part you will notice and enjoy as soon as you take that first corner, so GET ONE. There is a lot of information so we urge you to click below to read more on the ALTA web site.
19mm Adjustable Rear Sway Bar >> Check It Out Only $194.99msrp
22mm Adjustable Rear Sway Bar >> Check It Out Only $179.99msrp
End Links
Sway Bar End Links connect the end of the sway bar to an unsprung point of the suspension (usually the control arms, spindle or lower shock/strut body) transmitting the sway bars force to the suspension. OEM end links are designed "just enough" for weak OEM sway bars. Add a larger, stronger & stiffer aftermarket sway bar and the OEM end links will not hold up. Depending on the link they will, bend (reducing the sway bar effectiveness) or brake! (eliminating the sway bars effectiveness). In short, if you up grade your sway bars, up grade your end links.
Adjustable End Links >> Check Them Out Only $119.99msrp
P.S.R.S. - Positive Steering Response System
The MINI has very minimal adjustments to the front suspension, toe in or out only. ALTA has seen tremendous benefits from changing the levels of caster in the front. This increase in caster allows sharper more precise response from steering input. Decreases understeer and improves overall feel.
Also, the OEM lower control arm bushings supplied from MINI are a very gooey like rubber compound. While great to reduce road noise, they are miserable at improving handling. As a result even the most minor of imperfections in the road surface can cause the car to dart around. The ALTA PSRS uses a firm bearing material that prevents this. This inspires confidence in all driving conditions, and again adds positive steering response.
P.S.R.S. >> Check It Out Only $269.99msrp
ALTA Performance adjustable control arms are a great way to improve the handling of your MINI Cooper by adding strength, adjustability and reducing weight.
Our control arms are threaded to accept huge aircraft quality, Nylon impregnated, heim joint rod ends. This eliminates unnecessary welding and extra pieces, further increasing strength and allow for camber adjustment and smoother more accurate articulation.
The stamped factory control arms have soft rubber bushings pressed in both ends. While an acceptable choice for the street, they are not ideal for performance minded driving. ALTA adjustable control arms solve all of those problems with minimal increased noise, harshness or vibration (NVH) associated with other adjustable control arms.
Two sets of arms can be purchased to replace both upper and lower rear control arms. This can further increase rear end adjustment, remove even more deflection from the OEM rubber bushings and reduce weight even more.
Adjustable Rear Control Arms >> Check Them Out Only $269.99msrp
All Alta Performance Suspension Components Listed In This Post Fit And Work Great On All MINI Cooper Models From 2002-2010 And Are Projected To Work On All 2011 Models With The Possible Exception Of The Countryman.
ALTAPerformance
Do You Need/Want Springs, Coil Overs or Wheels Spacers?
If So H&R Is What You Need and ALTA is the premier H&R supplier to the MINI community.
H&R Sport Springs
The factory has simply let us all down (or should I say UP) with the stock ride height of our MINIs. The way it should have been is about 1.5" lower! These are an excellent compliment to your MINI! German made, lifetime warranty, easy to install. What more do you want?
This is an extremely nice upgrade to the car. Removes the excessive wheel gap and lowers the roll center. Improves steering response as well as the visual impact. Ride quality is improved over stock in most all situations.
Works with both standard and sport suspension struts.
Also, don't forget to check out an ALTA Swaybar to help reduce under steer. Combined these two will make a HUGE change in your daily commute or lap on the track!
Vehicle Lowering* Chart
R50 Cooper 1.0"F & 0.75"R
R52 Cabrio 1.4"F & 1.4"R
R55 Clubman 1.4"F & 1.4"R
R55 Clubman S 1.4"F & 1.4"R**
R56 Cooper 1.4"F & 1.4"R
R56 Cooper S 1.4"F & 1.4"R**
*Lowering specs will vary based on actual vehicle weight.
**For JCW Models lowering Spec will be 0.3" - 0.4" less as they start at a lower height.
H&R Sport Springs from ALTA >> Only $199.00
To Be Continued ...............
Old Aug 26, 2010 | 11:03 AM
ALTAPerformance
Suspension FAQ, Coming Soon
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
TJANK
Aug 28, 2015 04:51 PM
Tires, Wheels & Brakes
Aug 26, 2015 10:50 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
