'03 MCS: Oil Blow-back on air filter
Old Aug 25, 2010 | 06:02 PM
A2MCS's Avatar
A2MCS
Hi All,
Bought an '03 MCS 57K a couple months ago and when I changed the air filter, the bottom was covered w/oil. I checked/topped oil and in 2K miles I'm down 1/2qt oil w/no visible signs of seepage/leakage. OK, I haven't checked my 'new' air filter, but I'm pretty sure of the outcome when I do. Are we talking a valve/seal issue? Car runs and performs great, throwing no codes, but I want to put a CAI and 15% SC pulley, etc on it and want to know what I'm up against. Any insight is greatly appreciated.
Thanks!
Old Aug 25, 2010 | 06:14 PM
HRM's Avatar
HRM
I can't tell by the post, but many aftermarket reusable filters require oiling before use (with special oil) Often, after they get hot, oil can pool under the filter. At a cooler temp, it is stuck in the filter, but when heated, it drips.
Just a thought.
Old Aug 25, 2010 | 06:40 PM
A2MCS's Avatar
A2MCS
I wish it were that simple. It has a stock intake as of now. No smoke from the exhaust. I did buy/hang a cat-back system, but this was an issue prior to and I can't imagine anything to do with that.
Old Aug 25, 2010 | 06:48 PM
ED955S's Avatar
ED955S
Clean your IC. Must be very oily by now.
Old Aug 25, 2010 | 07:23 PM
msmax96's Avatar
msmax96
bad vlaves/seats need head recon do leak check test
Old Aug 25, 2010 | 07:29 PM
A2MCS's Avatar
A2MCS
msmax96, my worst fear. Any clue how much $$$? I got the car for 9K US, so I have room for recon/mods. ;-(
Old Aug 26, 2010 | 10:16 AM
Calz's Avatar
Calz
If its not burning a lot of oil and it is just pooling you may have a PCV stuck open... very rare though. If you remove the intercooler and its full of Oil sometimes the supercharger gear oil leaks past the seals and it looks a lot like fresh engine oil. I have never seen it where any of the oil would build up in the airbox
Old Aug 26, 2010 | 05:13 PM
MINI33342's Avatar
MINI33342
There is no way for oil to get to that location from the engine. It has to have come from the air inlet at the front of the engine or from the filter.
Are you using the stock paper filter? Was this the first time you have replaced the filter? Could it have had a K&N filter before?
Old Aug 26, 2010 | 06:39 PM
A2MCS's Avatar
A2MCS
Thanks Calz and MINI33342 for the replies. Clearly I have to let a mechanic look at it. The filter appeared stock to me, I have only had the car for 3K miles and it runs/performs great but I've never driven another MC. I'm taking that car to my mechanic at a body shop who is quite good, he rebuilt my cooling sys on my 540, but don't know his ability to diagnose MC issues. Changing all fluids Monday and will monitor the oil and check the air filter I replaced a month ago when I found it VERY oily. I do not know if it was SC oil or motor oil, but confident it was not an aftermarket filter requiring oil that had been overly oiled. No warning lights on, but I have not hooked it up to an OBDII reader w/BMW codes. I appreciate all of your thoughts and advice and hope I don't need a new head or I'll be 'tricking it out' for more $ than I had planned. thanks
Old Aug 26, 2010 | 06:56 PM
HRM's Avatar
HRM
Just so you know, they do make aftermarket filters for the stock airbox. The do look stock.
http://www.bavauto.com/fland.asp?par...urce=33%202239
Old Sep 13, 2010 | 06:29 AM
Medic_Coop's Avatar
Medic_Coop
I am having the same problem. New to me 06 MCS has black oil on the air filter. I did purchase an oil catch can.....hopefully this will catch the oil from blowing back. It seems it would be a known issue if there are so many aftermarket catch cans available.
silence2-38554
98
Sep 21, 2016 02:52 PM
devicemanager
Jun 17, 2016 06:18 PM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
Aug 21, 2015 08:44 AM
