brake job! HELP
Old Aug 23, 2010 | 04:14 PM
ROADDEVIL's Avatar
ROADDEVIL
brake job! HELP
im losing my mind, on the rear brake i cant get the piston back far enough to put the shoes on, im only doin the rear
AND YES I HAVE THE RIGHT PARTS i have the drivers side done already
the passenger side is givin me all three shades of hell
MY QUESTION
is there some magical way to move the piston back further? i have it in a vice and I tried bleeding it already
im a pretty big guy so i mean its on there i just cant get it to move...at all
HELP!
Old Aug 23, 2010 | 04:20 PM
FeydJM's Avatar
FeydJM
Rear has to twist and push in. What are you using to compress the piston, jus the vice?
Old Aug 23, 2010 | 04:24 PM
element's Avatar
element
i use needle nose pliers.. push and twist.. eventually the thread will catch and the piston will move in.. takes some force, is a pain until it moves and then you will know the trick! I sometimes hold the caliper against the pad carrier to get some good leverage.
I wouldnt use a c-clamp or anything that doesnt push or rotate at the same time..
Old Aug 23, 2010 | 04:25 PM
ROADDEVIL's Avatar
ROADDEVIL
never mind i got my BFH out and got it
thanks
Old Aug 23, 2010 | 04:26 PM
ROADDEVIL's Avatar
ROADDEVIL
it was so far out it was in a bind
Old Aug 23, 2010 | 04:34 PM
MINI33342's Avatar
MINI33342
You really need the Harbor Freight caliper tool....about $20
Old Aug 23, 2010 | 05:14 PM
Some Guy's Avatar
Some Guy
I just use a c-clamp, works a treat.
Old Aug 23, 2010 | 05:21 PM
MINI33342's Avatar
MINI33342
As long as the pivot doesn't pivot.......lol
Old Aug 23, 2010 | 09:14 PM
Calz's Avatar
Calz
The piston tool makes this job soo easy... its worth the money every time
Old Aug 23, 2010 | 09:37 PM
CooperS_rcr's Avatar
CooperS_rcr
Thank you for posting the info on the brake caliper tool. I am getting ready to replace my brake pads.
Old Aug 23, 2010 | 11:22 PM
Some Guy's Avatar
Some Guy
Huh? The rotating pivot on mine spun and let the caliper go right back in, no need to press and rotate at the same time.
Old Aug 24, 2010 | 04:36 PM
MINI33342's Avatar
MINI33342
Yes you do.....the piston is req'd to be turned as it is pushed back into the caliper. Never force it.
Old Aug 25, 2010 | 06:52 AM
cct1's Avatar
cct1
I think what Some Guy was saying was that the C-clamp rotated with the piston, so that the piston rotated when you tightened the C-clamp. At least that's what happend when I used a C-clamp, before I got the HarborFrieght tool (which I much prefer to the C-clamp).
Old Aug 25, 2010 | 10:02 AM
Calz's Avatar
Calz
The C Clamp can work but sometimes when the calipers are older and the E brake cables can be sticky it tough to get enough twisting force from the C Clamp. That rear piston tool makes everything so easy and fast
Old Aug 25, 2010 | 05:02 PM
MINI33342's Avatar
MINI33342
Old Aug 25, 2010 | 07:29 PM
Some Guy's Avatar
Some Guy
This. Sorry if I was unclear, the piston did rotate on the way back in.
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
