What brand of oil to use and how often to change?
Old Aug 22, 2010 | 09:11 AM
Sajuuk Khar's Avatar
Sajuuk Khar
06 MCS JCW.
This is my first car that needs synthetic oil.
What brand do you guys recommend and how often do you change it? Still every 5k or 10k like bmw recommends?
Im not sure what brand is in the car at the moment, all I know is they put synthetic in for me. Is mobile 1 a good choice?
ANy info would be greatly appreciated.
Old Aug 22, 2010 | 09:44 AM
hunter99's Avatar
hunter99
I use the Castrol euro syn that MINI recommends and change it every 5k. It might be fine to do it when the service indicator recommends but I feel better doing it more often.
Old Aug 22, 2010 | 10:33 AM
Agarwaen's Avatar
Agarwaen
Mobil One, Castrol Euro, Royal Purple are all good.
I change mine every 7500, half of recommend cycle. And in fact, tomorrow is time for a change.
There are also tons of threads on oil, do a search and you will find tons of info.
Old Aug 22, 2010 | 10:47 AM
SunnySideUp's Avatar
SunnySideUp
I use castrol synth...I don't do my own oil changes but I do buy the oil myself it saves a ton...I get my oil changed about every 10k but I do make sure I check it. My mini has 98k milles and there have been a few bumps in the road but overall it's been a pleasant motoring experience.
Old Aug 22, 2010 | 11:47 AM
Porthos's Avatar
Porthos
I used Amsoil for the first time right before MTTS and I like it but I am do fo another change cause of mileage.
Old Aug 25, 2010 | 07:29 AM
Sajuuk Khar
Are you guys posting in miles or km?
Im from Canada
Is changing it every 5000km too soon? thats about 3125 miles.
10,000km is about 6250 miles, that seems a little better for full synthetic?
Old Aug 25, 2010 | 07:34 AM
quikmni's Avatar
quikmni
I change every 7,500 miles. I am currently using Redline 5-40.
Old Aug 25, 2010 | 07:41 AM
Agarwaen's Avatar
Agarwaen
I was posting in Miles, Sorry.
Well, there are a lot of different intervals that us MINI drivers change our oil. Really the only way to determine the interval that is best for your vehicle is to send your old oil off to be analyzed. But that's on the far end of **** car care. Both 5000Km and 10000Km would be acceptable intervals. Really its your call on that one.
Old Aug 25, 2010 | 06:22 PM
Speedwing's Avatar
Speedwing
I use Royal Purple Synthetic and change at 12K miles or 1 year....and an OEM filter and new WELL LUBED O-ring.
Old Aug 25, 2010 | 07:04 PM
ellcapitan's Avatar
ellcapitan
Could you be specific about what exactly it is about a particular brand of motor oil that you "like"? Do you believe that you can feel a difference in engine performance from one brand to another (assuming the same type and weight)? ...Or that one oil lubricates any noticeable or measurable amount better than another in any particular given engine?
This tends to be a very controversial, and surprisingly sensitive, topic.
FWIW, I actually trust the car's computer oil counter. I believe that the people who designed the car and it's oil counter know more about the car's engine and about oil than I do. I also believe that oil-related engine failure (other than starvation...from not maintaining proper oil level) is the absolute LEAST likely fatal failure any modern car will face in it's lifetime. That's not to say engines will not and do not fail, just that the failures will likely never be attributable to whether the oil was changed at 3000 mile intervals or 15000 mile intervals (or to which brand of the proper type and weight of oil was used, for that matter).
Old Aug 25, 2010 | 07:22 PM
kb30's Avatar
kb30
pennzoil ultra 5w-30 or royal purple and third of a can of lubro moly mos2. Change every 5k. alot of short trips and mostly stop and go. I wanted to use mobil one 0w40 as recommended but the car seems so sluggish on it.
CM2011RG
Apr 12, 2016 12:44 PM
MINI VINI
Oct 13, 2015 08:57 AM
blackie
Aug 25, 2015 09:08 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
