Run Flat Tyres and the flat tyre monitor.....help
Old Dec 13, 2003 | 05:59 PM
jh2002's Avatar
jh2002
This morning I went and started up my car and the flat tyre monitor lights did not go away as normal. I got out and looked at the tyres and they all looked fine. It has been below freezing here in Chicago and tyres tend to lose pressure in cold temps. I held down the reset button and the lights went out. Is this a defect in the wiring since the flat tyre lights did not flash as the manual depicts?
Thanks,
JJ
Old Dec 13, 2003 | 07:34 PM
KiLO's Avatar
KiLO
Sometimes the tire pressure indicator light will come on if there is a difference in pressure between tires... If that comes on again, I would just go check the tires, and make sure you are running uniform pressure throughout.
Hope that helps!
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
Zettinger
Aug 25, 2015 04:04 PM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
