Suspension H-Sport or Alta adjustable trailing arms?
Old Dec 13, 2003 | 01:50 PM
silversurfer's Avatar
silversurfer
I am going to add adjustable trailing arms after fitting some H-sport springs and wanted to know if there are any advantages/disadvantages to having the rubber bushings with grease fittings like on the H-Sports or not like the Alta with heim joints?
Old Dec 13, 2003 | 03:27 PM
rb905678's Avatar
rb905678
Good Day,
I have the h-sport springs and needed to install adjustable lower control arms to reduce camber (looked like a bug ) I put the h-sport in for ease of adjustment and to stay away from heim joints, the lift in my jeep has hiem joints and they break and make noise.....
Old Dec 13, 2003 | 04:15 PM
Moorlockx's Avatar
Moorlockx
As both units are adjustable without dismounting one end from the car it boils down to a $40 with the H-sports and which type end you have a preference for. Heims are nice, but I don't think they'd hold up as well as the bushing type, in the all-weather day to day driving most people do. Put my vote for the H-sports...... And you can correct me if I'm wrong, but don't the H-sports carry nylon bushing to eliminate any give in the joint?
Old Dec 13, 2003 | 04:26 PM
jlm's Avatar
jlm
getting at the upper locknuts is a *****; the H-Sport, without them, is much easier to adjust.
Old Dec 14, 2003 | 01:22 PM
MiniPilo's Avatar
MiniPilo
Heim Joint have a tendency to produce slack over Time, I'd go with the h-sport.
Dan
Old Dec 14, 2003 | 01:43 PM
flyboy2160's Avatar
flyboy2160
i have h sports on order because of the dirt induced wear of heim joints and the easier adjustment using the central turnbuckle.
if you insist on heims, i suggest using boots. here's one source for boots and grease nippled heim joint arms
http://www.out-pace.com/raceboot.html
http://www.out-pace.com/algreasedmoly.html
there are other sorces for just the boots, but i don't have the links.
flyboy2160
Old Dec 14, 2003 | 02:22 PM
chigh's Avatar
chigh
Check Rossier Dyno for their products. Super craftsmanship as I have been to his shop and jknow someone who did a lot of mods (to 200 HP) on a Mini S. Probably at Helix also.
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
Emnotek
Sep 11, 2015 04:16 PM
Suspension Products
Sep 10, 2015 11:46 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
