door lock + automatic unlock (2 pulls on handle)
Old Aug 17, 2010 | 02:08 PM
MiniEOD's Avatar
MiniEOD
ok so i have a 2005 MCS
recently, the 2 handle pull to autounlock and open the door has not been working on my passenger side door
if i use the key remote to unlock, it goes in one try...if i use the interior lock / unlock switch it will go in one try...but if we pull the handle once, it only slightly moves the lock, i have to pull it like 10 times for it to *maybe* unlock...and then i can pull again to open the door
is this a common issue...is there a fix for this?... like i said it only happens with the autounlocking feature...not the buttons or keys
Old Aug 17, 2010 | 02:41 PM
ScottRiqui's Avatar
ScottRiqui
Since it works with the interior toggle and the remote fob, the electric actuator is fine, as well as the connection between the actuator and the door lock mechanism. It sounds as it something has gotten loose or is binding in the linkage between the interior door handle and the lock mechanism on your passenger door.
The best thing I could suggest would be to remove the interior door panel and observe the linkage as you pull the interior door handle.
Have you ever had the passenger door panel off for anything?
Old Aug 17, 2010 | 02:54 PM
MiniEOD's Avatar
MiniEOD
not that i know of...but i am the 2nd owner...i hate door panel removal
someone tell me it is easy on these cars
Old Aug 17, 2010 | 03:45 PM
Yeah.ThatsRice.'s Avatar
Yeah.ThatsRice.
We would be lying
Old Aug 17, 2010 | 03:46 PM
MiniEOD's Avatar
MiniEOD
Originally Posted by Yeah.ThatsRice.
We would be lying
damn....well....guess ill just have to let them out of the car with the center toggle switch... haha
Old Aug 17, 2010 | 03:51 PM
ScottRiqui's Avatar
ScottRiqui
It's not *that* bad. This page has the gist of it. Getting the padded portion of the arm bar off is actually trickier than getting the rest of the door off the car.
Dec 23, 2015 10:36 AM
xpunisherx
Sep 1, 2015 11:47 AM
coachvminis
Aug 17, 2015 01:42 PM
