Navigation & Audio How do you hook up external amp to stock non-HK head unit?
Old Aug 17, 2010 | 07:53 AM
cincycoopers's Avatar
cincycoopers
Hi all,
I am writing to ask if anyone has hooked up an external amp to the stock non-HK head unit. I looked to see if there are pictures of the back of the unit but could find any. Does this head unit have RCA outputs?
A few other questions:
-how is the remote wire hooked up also? Maybe splice into the power running from the battery to the head unit?
-are there special considerations for hooking up the amp since it would be for a subwoofer versus multi channel for component speakers?
Thanks in advance for you help!
Old Aug 17, 2010 | 08:32 AM
kirker912's Avatar
kirker912
There are no RCA outputs, but you could just tap into the speaker wires. Most amps have a special input for this. If your amp doesn't have this input they make converters from speaker level input to RCA output. See:
http://www.amazon.com/XANTECH-SLLC1-.../dp/B000P0UE38
The remote wire can come from the stereo power wire but make sure it's the switched wire and not constant power wire.
The amp will connect up exactly like a multi channel amp. If it has two channels check to see if it can be bridged to one channel.
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
yashmack
Aug 15, 2015 03:11 PM
MIminiclubman
Aug 5, 2015 09:14 PM
veevsato
Aug 5, 2015 04:42 AM
