What have you paid for these repairs?
Old Aug 9, 2010 | 03:43 PM
datjams's Avatar
datjams
Dropped off the MCS '05 today to the dealer for an oil change and a checking of the reappearing flywheel rattle, and they phoned to tell me it needs:
  1. Oil pan gasket -722.00
  2. Exhaust hanger -193.00
  3. Water pump 1248.00
They did phone back to say the price would be about 20% less due to a misquote on the labor rate, but I'm still in shock. They've been very helpful to me in the past, but I'm blown away now. What have you paid for these services?
Old Aug 9, 2010 | 04:06 PM
Eric_Rowland's Avatar
Eric_Rowland
If it's not under warranty, don't take it to the dealer. Find a local independent shop that works on BMWs and MINIs.
Old Aug 9, 2010 | 04:45 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
^+1.
- ahh, why do they say you need a new water pump exactly ?
- 200 dollars for replacing an exhaust hangar ? Something doesn't sound quite right there either, are you getting a new mid section to your exhaust with that maybe ?
Oil pan gasket a bit to get to as the sub frame has to be dropped, but an independant mechanic who knows MINI's can do way less time than a dealer.
Would also have the mechanic check the pulse generator seal below the supercharger, and main bearing seal while in there. Both are also known leakers besides the Oil pan gasket and may be contributing to the wet underside of the engine.
Old Aug 9, 2010 | 07:25 PM
healey67's Avatar
healey67
Just my 2cents but I have never had to drop a subframe to get the oil pan/gasket off.
and agreed replace the crankshaft sensor oring while in there.
Old Aug 9, 2010 | 07:53 PM
veggivet's Avatar
veggivet
$tay away from the $tealer$hip!
Old Aug 9, 2010 | 08:05 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by datjams
Dropped off the MCS '05 today... and they phoned to tell me it needs...
Sounds like you should search for a local indy shop. Where are you located perhaps we have recommendations.
Rich
Old Aug 10, 2010 | 10:02 AM
CrazyIvan's Avatar
CrazyIvan
Water pump is a fairly easy job. Make sure you change the S/C oil while your doing it on both sides. And I would get two new o rings and a new flange that bolts on the block. Oil pan should be a pretty straight forwards change.
Way overpriced.
Fordgt4
Oct 10, 2015 10:42 AM
tristanwelch95
Sep 30, 2015 08:58 AM
Samhillrocks
Sep 29, 2015 12:55 PM
MiniUnz
Sep 14, 2015 11:11 AM
sempaipaul
Sep 9, 2015 05:55 PM
