R56 Triple Turn Signal?
Old Jul 19, 2010 | 08:04 AM
SpyCar520's Avatar
SpyCar520
Triple Turn Signal?
I apologize if this has been answered already. I just got a new 2010 MCS and I am so frustrated with setting up the triple turn signal option. I have followed the instructions in the car manual as well as things I have found online. When I scroll through the settings, the option simply is not there. I have tried it with the ignition on as well as off and still no luck. Is there something I am missing?
Thanks in advance!
Old Jul 19, 2010 | 04:28 PM
Porthos's Avatar
Porthos
Give me a few minutes I will do a video.
Old Jul 19, 2010 | 06:28 PM
klricks's Avatar
klricks
Thanks in advance!
Ignition must be on which means that the gas gauge etc. will be lit up.
Normally you would have to get in and close all doors. Then press the start button 2x without pressing the brake or clutch. Go to menu with key/checkmark. Or you can just start the engine to have the full menus.
If you just press the start 1x (accessory) then you will only get the radio and a subset of the menu items which does not include the turn signal 1x 3x options.
The above is for Comfort Access option with FOB in your pocket.
If you don't have CA or if you do have CA, (and want to use the FOB), then put the FOB in the slot. Then press the start 1x without brake or clutch. You should see the fuel gauge light up. Then go through the menus as above.
Old Jul 19, 2010 | 06:36 PM
Porthos's Avatar
Porthos
Make sure the car is on and not in motion.
UncDeo
Nov 4, 2019 04:08 AM
rob&JCW
Feb 21, 2018 02:41 PM
molala
Oct 2, 2015 01:53 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Suspension Products
Sep 2, 2015 10:32 AM
