Navigation & Audio Rear Speaker fubar on HK
Old Jul 18, 2010 | 05:32 PM
LaurelEdition's Avatar
LaurelEdition
One month old and the rear channel(or 1 speaker) is vibrating and breaking up like it's a 10 year old speaker. Are the HK speakers junk. Should I upgrade now? Is there a plug and play to fit in with no modifying. Thanks
I think this should be posted on Stock Problems/Issues
Old Jul 18, 2010 | 05:42 PM
Porthos's Avatar
Porthos
Warranty. You shouldn't be having that problem.
Old Jul 18, 2010 | 05:46 PM
LaurelEdition
Thanks. It's such a hassle going back I'd just as soon replace it myself...but I'll call them and see if I can bring it in a wait.
Old Jul 18, 2010 | 07:04 PM
Porthos's Avatar
Porthos
Loaner from them if it takes too long
Old Jul 18, 2010 | 07:13 PM
LaurelEdition
Gotcha...I'll call sometime Mon PM. I have not used service yet. We'll see how good(or bad)they are. I would not mind buying after market if they fit right in....that would be too easy.
Old Jul 18, 2010 | 07:18 PM
Mini Mee's Avatar
Mini Mee
Patches, Scrubbie, Scratchie
Old Jul 18, 2010 | 07:26 PM
LaurelEdition
I need a calculator. Chit is adding up fast
Old Jul 18, 2010 | 07:38 PM
Mini Mee's Avatar
Mini Mee
Whoooooo and I'm shopping for a 10 maybe I'll hold out till the perfected 11's hit the streets
Old Jul 18, 2010 | 07:43 PM
LaurelEdition
perfected?
Old Jul 18, 2010 | 07:58 PM
daflake's Avatar
daflake
If I had to stab at it, it sounds like your amp died. Also, if this is like the first gen, I doubt you can just swap stuff out with this system.
Old Jul 18, 2010 | 08:03 PM
cop1406's Avatar
cop1406
You need to take it in. You paid 750 bucks for the H/K system. Make them fix it properly. I like mine, sounds great.
Larry
Old Jul 18, 2010 | 08:46 PM
rkw's Avatar
rkw
Go with the warranty repair. The HK speakers are designed specifically for the HK amp and have some nonstandard characteristics that aren't simple plug and play with typical aftermarket speakers. They are like component speakers with no crossover (electronic crossovers are in the amp), and the rear speakers are coaxial (dual) speakers that are on separate amp channels (total of 4 rear speakers on 4 amp channels). And as mentioned before it could actually be an amp channel, not the speaker that is blown.
Old Jul 19, 2010 | 07:00 AM
LaurelEdition
When the bass and volume go up slightly the rear right speaker has a nasty sound. If the bass is at "0" and the fade is adjusted more to the front it's ok. I will have the agency address it. Thanks for your replies
Old Aug 24, 2010 | 12:20 PM
ksaim's Avatar
ksaim
I love my HK speakers -- granted it's been just under a month, but they sound great and put just the right amount of THUMP in my Clubbie.
Old Aug 24, 2010 | 02:11 PM
fishbert's Avatar
fishbert
Does the non-HK hifi amp have the same feature?
I am about halfway through adding HKs to my early-2009 hifi R56, and it'd be nice to know if I should budget for an amp swap down the road as well.
woodstudio
Mar 15, 2020 08:28 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Mini'mon
Aug 26, 2015 01:02 PM
OutMotoring
Aug 6, 2015 09:32 AM
