Tool for oil filter change?
Old Jul 18, 2010 | 02:35 PM
TT32V54's Avatar
TT32V54
Alright.. I like to do my oil myself and dont feel like paying the dealership an arm and a leg to do an oil change..
Last time I changed my oil on my 05 mini S.. the oil filter cap was the biggest PITA to get off..
Surely someone makes a socket that fits perfectly.. Can someone point me in the right direction, or at least give me a size?
Thanks!!!!!
05 mini s
Old Jul 18, 2010 | 02:37 PM
TT32V54's Avatar
TT32V54
I just found this.. will it work?
http://www.minicarparts.net/Parts/W136.cfm
Old Jul 18, 2010 | 02:41 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That would do it. A regular 36mm socket doesn't leave much room for maneuvering.
I had bought my oil filter socket from the dealer, actually, but this was more than 7 years ago. I don't think anyone else made them back then.
Old Jul 18, 2010 | 02:50 PM
TT32V54's Avatar
TT32V54
cool! just ordered it! thanks
Old Jul 18, 2010 | 05:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I use a cheapo one from advance auto parts. I think it's a powerbuilt, it works fine. There are some that are too tall so get the shortest one you can find. Also it only cost about $7
Old Jul 18, 2010 | 05:23 PM
Capt_bj's Avatar
Capt_bj
I bought several b4 I bought the sears craftsman 1/2 inch unit which IS shallow enuf to work. Been using it for several years.
Old Jul 18, 2010 | 05:51 PM
NightFlyR's Avatar
NightFlyR
When removing the oil filter, housing, has anyone found that it is very tight, then you can losen it a quarter of a turn or so, then it gets tight again?
Old Jul 18, 2010 | 06:55 PM
r2millers's Avatar
r2millers
Yes. It tightens because of the drag with the o-ring. No worries, just be sure to ALWAYS use the new o-ring that comes with your new filter elements. I have changed the filter without changing the o-ring and it always leaks after. Never again with the old o-ring..
Old Jul 18, 2010 | 07:19 PM
Mini Mee's Avatar
Mini Mee
+1
Old Jul 18, 2010 | 07:40 PM
Dex05S's Avatar
Dex05S
I took a standard length 36mm socket and machined to about half its length, any machine shop can do this with no problem. Add yourself a fumoto drain valve and the oil changes are as easy as it gets!
Old Jul 18, 2010 | 08:17 PM
wrh3's Avatar
wrh3
I found mine on eBay or some online vendor, it is shorter than the one I had:
Old Jul 19, 2010 | 11:15 AM
Crashton's Avatar
Crashton
I'm using one just like that & it works like a dream. Bought it at Pep Boys for the same price too. It was back hanging with the other filter wrenches, the card said BMW filter tool.
Old Jul 19, 2010 | 11:43 AM
MINICHEF's Avatar
MINICHEF
Got mine on Amazon for a great price. It is a LISLE 14500.
Old Jul 19, 2010 | 11:50 AM
T0mmy's Avatar
T0mmy
I just use a 36mm Craftsman socket I bought from Sears for like $8. I've never had a clearance issue. (lucky I guess as I didn't consider depth when i bought it)
Old Jul 19, 2010 | 11:57 AM
MNCRYSS's Avatar
MNCRYSS
Definitely more touchy than a regular filter change. Be sure to put some clean oil on the new gasket too before installing the canister again. I pinched a gasket once and didn't realize it until I started the car and it was a gusher. Luckily, I had a few other filters on hand to use another gasket.
Kimolaoha
Jul 5, 2023 01:04 PM
Beau B
12
Aug 24, 2015 01:50 PM
Aug 19, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
