Suspension Koni FSD Shocks
Old Jul 14, 2010 | 10:55 AM
R53's Avatar
R53
Koni FSD Shocks
I just wanted to know if these shocks lower the car anymore coupled with their sport springs?
Old Jul 14, 2010 | 11:16 AM
OldRick's Avatar
OldRick
No.
No shock absorber will lower a car unless you are going from a gas-pressurized shock to a non-pressurized one.
Old Jul 14, 2010 | 11:20 AM
putttn's Avatar
putttn
Actually my FSD's raised my car a bit
Old Jul 15, 2010 | 07:59 PM
ZippyNH's Avatar
ZippyNH
Your struts must have been pretty flat....
mine was no-change....except for the ride!!
Old Jul 20, 2010 | 09:56 AM
tonester's Avatar
tonester
I just ordered a set of FSDs this week. I've read that Koni recommends using stock springs (non-lowering) with them. I have 60,000 miles on my MCS currently and the driver side front OEM shock is leaking. I figured since i'm already, taking out the shock assemblies, what else should I replace? Should I get new springs and shock mounts also?
advice please.
Old Aug 18, 2010 | 07:49 PM
goldcountrymini's Avatar
goldcountrymini
I'm a novice here... so replacing the shocks will smooth the ride out? Im currently running h-sport springs on stock shocks. I'm thinking of either going with Megans (cost effective) or just picking up FSDs and using my h-sport springs.
thoughts??
Old Aug 19, 2010 | 05:20 AM
ZippyNH's Avatar
ZippyNH
Lowering a car can cause very fast shock wear...unless the shocks are a bit shorter, and made for lowering, like the Koni sports...they are like the yellows, but shorter.
With the fsd's, they may fail faster, and leak on a car with lowering springs...the valves get beat up...
Lowering a car with springs is a bit of a hack job...it is easy, but not ideal, and causes problems like tire wear, and geometry problems...IMO if you really want a lowered car, get a set of cheap coil-overs. Thathaving been said, a car can be lowered with springs, if you replace the correct compotents, and get an alighnment.
Old Aug 19, 2010 | 05:23 AM
ZippyNH's Avatar
ZippyNH
As stated previously, Koni recommends that FSD's be used with stock height springs....
JCW should be fine...they are a mild drop, just like TSW springs, which folks have had good luck with fsd's
Old Aug 21, 2010 | 08:42 PM
LUCYBUG's Avatar
LUCYBUG
Had my FSDs and H-Sport lowered springs for over 40k miles - no problems noted or expected.
RobbyD
Jan 29, 2019 01:22 PM
pahg
Oct 5, 2015 11:50 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
