Suspension Installing Cabrio Front Strut Tower Support Issue
Old Jun 30, 2010 | 08:26 PM
JCWMiniNewb's Avatar
JCWMiniNewb
OK, so I am in the process of installing my first modification to my mini this week and ran into a snag. While installing the front Cabrio Strut Tower Support to my 2005 MCS, one little rubber screw resists all attempts at removal. I was wondering if anyone has run into the same issue...
Full instructions I am following are listed here:
http://www.billswebspace.com/MiniCab...stallation.htm
The rubber screw at issue is in the center of this picture (gold hexagon-looking bolt)...
According to the instructions the guy was able to loosen this with his fingers. Unfortunately for myself and my father, even with pliers we are unable to loosen this screw. It's as if the rubber has fused with the bracket underneath it. I can't find this part on realoem.com, so I am not sure what part number it is. I am afraid to force it any more than I have because I don't want to be without a car lol!
Anyone have any ideas on how to loosen this thing without destroying it? If need be, anyone know where I can find a replacement in case I destroy it? I'd rather have the replacement in hand before going forward.
Old Jun 30, 2010 | 08:29 PM
Agarwaen's Avatar
Agarwaen
That is a cap covering the pressurized air-conditioning system, can't say I'd recommend removing it.
Last edited by Agarwaen; Jun 30, 2010 at 08:34 PM. Reason: Ill explain my edit in another post.
Old Jun 30, 2010 | 08:31 PM
JCWMiniNewb
I believe you are talking about the black cap above the golden hexagonal screw I am referring to.
Old Jun 30, 2010 | 08:37 PM
Agarwaen's Avatar
Agarwaen
As you have said, I was speaking of the red circle. Are you speaking of the Green circled area?
Old Jun 30, 2010 | 08:39 PM
JCWMiniNewb
The green area is exactly what I am referring to. I'm not as computer savvy with images, so I appreciate your edit of the pic
Old Jun 30, 2010 | 08:44 PM
Agarwaen's Avatar
Agarwaen
Unfortunately, My R53 is before the date that they started pre-drilling those holes. So, I cannot comment on removal of these pieces. I was just trying to make sure you didn't vent your A/C gases everywhere.
Old Jul 1, 2010 | 01:51 AM
JCWMiniNewb
Well I found the part online as #64119175671 in case I destroy it when removing it. Anyone have an idea on how to remove it though?
Old Jul 1, 2010 | 03:16 AM
HRM's Avatar
HRM
Spray with some lubricant, wait a bit, then get a ratchet and crank it out. If it needs replacing, then you have to get a new one.
Pliers won't work on many car repairs.
Old Jul 1, 2010 | 04:07 PM
JNagy's Avatar
JNagy
Just so you know for future reference taking off that cap will not let the pressure out, its just a cap. There is a valve inside the line.
Old Jul 1, 2010 | 04:29 PM
wrh3's Avatar
wrh3
I was able to break it loose with a small pair of pliers but it was just more than hand tight. You can always try a little PB Blaster if its being stubborn, this has worked for me more times than I can count.
Old Jul 14, 2010 | 06:09 PM
JCWMiniNewb
That little rubber screw was just a nightmare. After spraying with WD40 a few times, the rubber just broke down and disintegrated. The metal portion on the bottom had fused to the metal plate underneath. Took a screw driver and hammer and worked that thing for about 15 minutes before it started to move.
It's all done now though. My first mod is done!
Old Jul 14, 2010 | 06:47 PM
ZippyNH's Avatar
ZippyNH
Congrats....mine was tuff to remove too. Congrats on having complected your first mod.
One suggestion....the rubber bolt/washer is there to dampen the vibration for the AC line....you might want to fashion something so the line does not fail from vibration!! A couple of plumbing washers might work...a bit of creativity can go a long way.
Old Jul 14, 2010 | 06:49 PM
JCWMiniNewb
I ended up buying the exact same oem part from ECS Tuning haha.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
