Navigation & Audio HK Intermittent crackle in all speakers
Old Jun 29, 2010 | 07:17 AM
stevendoll's Avatar
stevendoll
I have a 03 MCS with factory HK system. I have strange problem with intermittent crackling in any/all speakers. It will sound fine then randomly a crackle/static sound will appear and last for 30-sec to 2 minutes. If the head unit is turned off during this, the sound will still persist. The dealer suggested it was the HK amp. Any ideas, suggestions for fix?
Old Jun 29, 2010 | 11:37 AM
Eric_Rowland's Avatar
Eric_Rowland
Sounds like the amp. There has been some discussion of trying to fix it, but replacement is the path of least resistance.
Old Jun 30, 2010 | 09:26 AM
davecrook1's Avatar
davecrook1
defo the amp on its way out.. mine did this and lasted a few months until i came to start it one day and there was no sound at all.. and this is still how it is..mini amplifiers are soooo expensive.. so ive been searching for other ways to use the speakers and wiring already in the car and use an aftermarket amp.. it seems some have done this.. and i need to try it as im missing not having music in the car.!!!
Old Jan 12, 2016 | 02:51 PM
rosaymaan's Avatar
rosaymaan
HK speakers crackle when head unit is off..
bumping this thread. I have been experiencing this problem lately. although mainly from the passenger side tweeter and the rear passenger side speaker. lately its gotten really bad (and annoying). I tried replacing the rear passenger speaker but the sound persists so its not the speaker... how do i fix this?? the oem amp is very expensive.... anybody have any luck fixing on the cheap?
Old Jan 12, 2016 | 03:52 PM
rosaymaan's Avatar
rosaymaan
Old Jan 13, 2016 | 04:46 PM
joylove's Avatar
joylove
Dry joints in the amp. Check the connector for water ingress and corrosion, then you are looking for dry PCB joints.
Old Jan 13, 2016 | 11:16 PM
rosaymaan's Avatar
rosaymaan
I have no idea what you just said lol. Can you explain? can you buy dry pcb joints?
Old Jan 14, 2016 | 07:38 AM
Fly'n Brick's Avatar
Fly'n Brick
He's talking about the power and output wiring connectors associated with the amp. PCB refers to the white plastic wiring connectors.
He's got a point. It would be worth checking out before trying to replace the whole kit.
Filmy
15
Jun 6, 2023 06:27 AM
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
