Suspension Are there any 18 or 17 inch wheels that will clear lowered coilovers and BBK's?
Old Jun 20, 2010 | 11:12 PM
Mike S's Avatar
Mike S
As per the title, any wheel that fit that criteria without spacers? I LOATHE spacers. I would have to change my nice R105 wheels then
Old Jun 21, 2010 | 10:29 AM
quikmni's Avatar
quikmni
Depends on the size of the BBK rotors, size of the caliper, size of shock body, size of the wheel, and offset of the wheel.
Old Jun 21, 2010 | 11:57 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I found this thread, but I'm not sure if it will help you or not in figuring out what rims are compatible: https://www.northamericanmotoring.co...w-jcw-bbk.html.
Old Jun 21, 2010 | 01:06 PM
Mike S's Avatar
Mike S
Sorry for not being more descriptive.
I have the R53 BBK, so it's not as big as the R56 version. My old R95 wheels cleared those by quite a margin. So 17 or 18 diameter wise will be fine.
It's the ET's that are the tricky part figuring out :(
Old Jun 21, 2010 | 01:18 PM
JumpingJackFlash
Well, to my best knowledge, R53 JCW brakes and R56 OEM brakes are the same size. Having said that, you should be able to use any 16" or larger rim with a 38-50mm ET. The wheel shop you go to should provide a JCW brake option for spec selections. I'm sure you've seen this link before: https://www.northamericanmotoring.co...re-weight.html. Use the OE links as guides to pick your ET. Looks like alot of them have an ET of 45.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
TJANK
Aug 24, 2015 06:11 PM
OutMotoring
Aug 6, 2015 09:32 AM
