Drivetrain Atla catalytic converter replacement.
Old Jun 9, 2010 | 04:27 PM
HRM's Avatar
HRM
The second O2 sensor is tossing a fault. I am thinking it may be easiest to just replace the converter rather than make a work around. They are not that expensive and I am hoping this is the cause (probably is based on what I have read). It sounded like they got a bad batch of converters and changing it out might just be the fix I need.
Any way, what are the recommendations out there. I see Magnaflow, High power, etc. They all must be similar in function. Here are a few I found just looking on the web.
http://www.rpmoutlet.com/powercat.htm
Any proven solutions and experience out there?
Old Jun 11, 2010 | 07:53 AM
ALTA_Jarid's Avatar
ALTA_Jarid
What fault are you getting?
Old Jun 12, 2010 | 04:47 PM
HRM's Avatar
HRM
Thank you for asking. I erased it and can't find the paper I wrote it on (wife is efficient). It has been causing a CEL since right after the exhaust was first installed. Alta offered to "look at it" if the entire thing was shipped back to them, so the car has just been driven around with the CEL light on for years. The code P0422 is one that popped up often, but I can't be sure it was that one this time. I don't want to give you the wrong information and I won't be driving the car until next week, so I won't guess at the most recent code. It will pop up quickly though once the car is being driven, so it will be Tuesday when I know it for sure.
Old Jun 17, 2010 | 08:46 AM
Elessar's Avatar
Elessar
I'll take a guess and say its P0420 unless you have a couple defoulers installed.
Old Jun 25, 2010 | 07:05 PM
HRM's Avatar
HRM
OK, I want to be perfectly fair since my post had an obvious slant to it.
The code was something the first owner of the car couldn't fix. He just lived with it. The code was always about cat efficiency *(meaning second O2 sensor was involved) The primary O2 sensor was replaced just at the same time I bought the car (he found it in his garage) I drove it 167 miles with the new primary installed and then cleared the code. Since then, the code has not re-appeared in 400 miles which according to him is a new record. If it does reappear, I will make note of it here, but I find it really interesting that replacing the first sensor will make a code generated by the second one go away. Not something I would have thought possible.
shorenetworks
Nov 4, 2019 06:18 PM
Sep 18, 2015 02:44 PM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
Sep 4, 2015 12:20 PM
