bad grounds
Old May 28, 2010 | 08:58 PM
michele r53's Avatar
michele r53
bad grounds
has anyone had a problem with getting a bad negative
Old May 29, 2010 | 03:44 AM
chadtoolio's Avatar
chadtoolio
need more info, can you explain?
Old May 29, 2010 | 06:01 AM
michele r53
I'm experiencing a problem with my led parking lights I'm thinking its a bad neutral. Mayb they aren't seeing a clean signal. I was curious if anyone else had issues with a neutral
Old May 29, 2010 | 06:39 AM
chadtoolio's Avatar
chadtoolio
All it should take is a power and a ground.....remember LED is a Light Emitting Diode, so power can only flow through one way, so they need to be installed the correct way. Other than that, break out a DVOM and check your power and grounds. Are they ok?
Old May 29, 2010 | 11:43 AM
michele r53
Their seemed to be a problem on the passenger side causing them to blink looks like I cleared the problem. All back together and with the key on Theres no more pulsating.
Filmy
15
Jun 6, 2023 06:27 AM
riff42
Sep 22, 2015 03:07 PM
Sc00terbum
Sep 11, 2015 09:07 AM
OutMotoring
Sep 8, 2015 06:27 AM
