Ticking or Tapping noise in Drivers side Rear
Old May 25, 2010 | 04:02 PM
vizcarmb's Avatar
vizcarmb
As the title says, there is a ticking or tapping noise coming from that area. I can only hear it at a slow speed or when it is coasting. I'm thinking its a wheel bearing, but I wanted to know your thoughts on this.
2003 mini base 108k miles.
Old May 25, 2010 | 04:49 PM
HRM's Avatar
HRM
First thought....nail in tire...
Old May 27, 2010 | 03:19 AM
lp01's Avatar
lp01
Does the noise frequency increase with speed, that is, do you hear more ticks per second when speed is higher?
Cheers
Old May 27, 2010 | 07:18 AM
vizcarmb's Avatar
vizcarmb
Yes it does, but it will disappear when the speeds are higher. Or I just can't hear it when moving at a faster speed. I will have to remove the rear seats to confirm that it does. But when I lifted the car and turned the wheel, it only clicked once and the clicking stopped after turning the wheel at different speed intervals by hand.
Old Jul 11, 2012 | 04:54 PM
mikeym's Avatar
mikeym
Did you ever figure this out? Nail in tire? Wheel bearing?
Old Jul 11, 2012 | 05:51 PM
vizcarmb's Avatar
vizcarmb
It was the brake pads itself. the type of pads I had made a gap between the carrier and the brake pad clip. So I put a shim in between to make the noise go away. I just used cardboard paper
maestro39
Oct 27, 2015 02:38 PM
one73ronin
Aug 19, 2015 12:36 PM
bugeye1031
Aug 15, 2015 08:14 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
