Power Steering lines replacement
Old May 24, 2010 | 05:05 AM
gsxspooling's Avatar
gsxspooling
Reposting in a more appropriate section....
Wisemen, The cooper S is leaking power steering fluid from one of the hoses (not sure if feed or return line). My original plan was to get a comparable hose from the local auto parts store, but this evening I was shopping on the FastMini.net site, and saw that they sell these hoses for $54 a pop! Is there something special about the hose that I am missing?
Thanks in advance!
Old May 24, 2010 | 10:13 AM
gsxspooling
50 views, and no reply?
Old May 24, 2010 | 10:46 AM
miniconcarne's Avatar
miniconcarne
High pressure, with rubber and hard line integrated to contour fit the tight confines under the pump=pricey!
Old Jul 6, 2010 | 05:52 PM
JRhea's Avatar
JRhea
I'm guessing they quoted you the low PSI side is $54.00. The high PSI will run in excess of $200.00. I know from experience.
If you make the repair yourself, make sure the metal tubing isn't rubbing against the PS pump bracket. My dealer installed my first high pressure line for about $400.00. 19 months later they replaced the second one free of charge because the tube was touching the bracket and it rubbed a hole in the tube.
A leak in the high PSI side can cause the oil to spray on the exhaust system or engine causing wisps of smoke to come up through the hood, like your car is on fire....and it could be. Leaks in the low PSI side will drip and leak down and coat the underside of the car.
Good luck.....Caution>>>>>> "only" use the recommended power steering fluid from MINI or a MINI parts depot. Regular auto parts stores will try to sell a standard power steering fluid>>>>>,don't ruin your system with theses fluids, they can harm your pump seals.
Old Jul 6, 2010 | 06:34 PM
wrh3's Avatar
wrh3
Way Motor Works has the pressure line for $65 and the suction line for $57.
Old Jul 10, 2010 | 04:08 AM
JRhea's Avatar
JRhea
That was a great web site you posted! Could be helpful for future projects.
JR
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
