oil leak
Old May 22, 2010 | 05:06 PM
mini22's Avatar
mini22
oil leak
So i have an oil leak under the coil. I thought it was my valve cover gasket so i replaced it and it still is leaking oil on to the header. Could it be the o rings that is on the coil bolts? Or is the valve cover just bad now? Thanks
Old May 22, 2010 | 05:14 PM
JNagy's Avatar
JNagy
have you checked the oil filter?
Old May 22, 2010 | 06:32 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If a coil pack bolt is overtightened, somtimes one or more brass sleeve(s) pressed in the cover pulls out.....
Old May 23, 2010 | 07:20 PM
mini22's Avatar
mini22
So what can i do to correct this problem? Thats what it looks like cause when i tighten the coil on there is still play.
Old May 23, 2010 | 11:56 PM
Fatherdeth's Avatar
Fatherdeth
You should probably try a new valve cover. And in the future, don't tighten the coil down too tight. I know it seems like it might not be on that well, but it won't come off if you just snug it down.
Old Aug 1, 2010 | 09:19 PM
Mini_Chan's Avatar
Mini_Chan
Where is the valve cover gasket located? I brought my car to the dealership for a 30 point inspection, and they said my valve cover gasket is leaking? The dealership wants $230 plus labor I think, if I can do this myself it would be great.
Old Aug 3, 2010 | 09:15 PM
plasticknives's Avatar
plasticknives
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
