Suspension H&R Spring Question
Old May 10, 2010 | 07:42 AM
rjtrout2000's Avatar
rjtrout2000
H&R Spring Question
So I am looking at different H&R part numbers and according to the German website, the part number reserved for the convertible actually will work on the R50 or R53 coupe. The drop is much more substantial on the convertible part numbered spring. Does anyone know why this wouldn't work?
Old May 13, 2010 | 01:48 AM
CRoth's Avatar
CRoth
My guess is that it woul be a stiffer spring due to the added weight of the convertable. I have H&R Sport Springs on my R53 and they are plenty stiff. I woul go with the ones that are designed for your model if I were you. They have a nice drop as well. Check out my gallery if you want to see what to expect.
Chad
Old May 13, 2010 | 04:15 AM
Keano's Avatar
Keano
What ^ said plus as your car would be lighter yours wouldnt drop as much as the conv would.... Thats why the JCW suspension kit has difference springs dependant upon the level of factory fit spec - adjust the rating so that it gives a uniform drop...
Old May 13, 2010 | 06:55 AM
rjtrout2000
Sounds like the coilover option may be the safest and easiest way to drop the car past 1 inch. Thanks for the input!
Old May 13, 2010 | 07:46 AM
Keano's Avatar
Keano
and the more expensive option...
Springs work fine so long as you get the right ones - i.e. not those meant for fitment to the conv if yours is the coupe....
No problems with my H&R springs with JCW shocks
Old May 13, 2010 | 07:50 AM
iwashmycar's Avatar
iwashmycar
Yeah springs will drop you over an inch just fine..
psmith27616
Suspension
11
Oct 26, 2016 04:57 AM
melscoop
Mar 30, 2016 06:56 PM
G1HQ
Aug 28, 2015 01:41 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
