Horn not working, what to check/where to look?
Old May 4, 2010 | 04:00 PM
Wilco's Avatar
Wilco
The title pretty much says it all. I just picked up my first mini (an 08 R56 MCS, LOVE IT!) and the horn isn't working.
It had a salvage title, so the warranty is voided (so I'll try the DIY approach first), and I believe the airbags deployed prior to the rebuild. I'm thinking the horn was probably just not reconnected when the new airbag was installed, but I'm not sure what I should check.
Any ideas/suggestions?
Thanks!
Old May 4, 2010 | 04:19 PM
Wilco's Avatar
Wilco
Update: I checked the fusebox and the horn fuse is good. I could hear a relay clicking when I push the steering wheel, so it must be something after the fusebox.
Is the horn activated directly by a relay, or does it tell the computer to activate the horn?
Old May 4, 2010 | 05:23 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Was it a front end collision ? Maybe check to see if they neglected attaching the plugs to each of the horns esp if your MINI had extensive frt end damage.
I dont believe the BCM has anything to do with your horn activation.
Melvinyip
Apr 17, 2020 09:28 AM
KrisMiss
Jan 3, 2016 02:02 PM
trw92a
Aug 26, 2015 01:47 PM
minipopkart
Aug 13, 2015 05:22 AM
