R52 Backup sensor
Old May 4, 2010 | 08:00 AM
PetesPepperWhite's Avatar
PetesPepperWhite
Backup sensor
The backup sensor in my 07 Cabrio keeps blowing fuses. Anyone else have this problem? Thanks!
Old May 4, 2010 | 09:50 AM
rkw's Avatar
rkw
The fuse F41 for the backup sensor is also used for the power steering fan, which is known to fail frequently. You should get it checked out. It is potentially a safety hazard.
Old May 4, 2010 | 11:18 AM
blue lightning's Avatar
blue lightning
I had the same issue with my 07, and as the other person said, have the power steering fan checked. The power steering fan was bad in my Mini.
Old May 6, 2010 | 03:58 PM
sunolmike's Avatar
sunolmike
Power steering fan?
I assume the power steering fan cools the power steer pump (which I understand to be electric). Is that on all the time? I assume that if it fails you can cook your power steering pump which I understand is electric.
The reason I ask is that I got my car back from the dealer and the back up beeper was not working. Since my bike rack makes the back up beeper whenever I shift into reverse, I wasn't too concerned when it didn't work. It was a "feature" that I wish had an on/off switch.
I should check the fuse (I have had the car for almost 3 years and have not yet needed to open the fuse box).
Old May 7, 2010 | 11:58 AM
101dals's Avatar
101dals
I'm on my third fan for my cabrio. Weak link in the mini's armor....
Old May 9, 2010 | 09:28 PM
miniola's Avatar
miniola
Yup. Power steering fan. I've had a couple too.
Old May 13, 2010 | 11:02 AM
PetesPepperWhite
That was the problem...you would have thought the dealer would have checked it out without my telling them-thanks guys!
Old May 14, 2010 | 11:19 AM
sunolmike's Avatar
sunolmike
Fuse 41?
I opened both the fuse box under the hood and the fuse box on drives side kick panel. The fuse numbers don't go up to 41. Any suggestions?
Old May 14, 2010 | 12:22 PM
rkw's Avatar
rkw
What fuse number does yours go up to? This was posted in another thread: https://www.northamericanmotoring.co...nd-wiring.html
Old May 26, 2010 | 02:49 PM
sunolmike's Avatar
sunolmike
fuse 39
It looks like my "fuse 41" is fuse 39. Not blown which means my backup warning is due to some other problem. Off to the dealer...
twriter
Oct 2, 2015 03:14 PM
sempaipaul
Sep 18, 2015 03:05 PM
StrongIslandMini
Sep 15, 2015 06:57 PM
Sep 14, 2015 12:48 PM
TREX
R58 :: Coupé Talk (2012+)
Sep 5, 2015 02:59 PM
