Rear brake rotor removal 06 Cooper
Old May 2, 2010 | 04:42 PM
jhruby's Avatar
jhruby
What is the size of the torx screw that secures the rear rotors on a 2006 Mini Cooper?
Old May 2, 2010 | 05:51 PM
LiquidSunshine's Avatar
LiquidSunshine
It's a T50 torx. Just did them last weekend. It is easiest to loosen with the calipers still attached and the parking brake engaged, but you can do it without if need be.
-Peter
Old May 3, 2010 | 08:46 AM
rsvp9146's Avatar
rsvp9146
You also don't need to remove the caliper frame to remove the rotor. Be sure to put a small dab of anti-sieze compound on the bolt.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
StealthR53
Aug 8, 2015 10:59 AM
